Panasonic Viera TC-L32U22 no picture
  • pr0cess0r
    • Jan 2011
    • 110
    Hello, the tv turn on but there is not picture and the power ligh stay on. I think it may be a firmware probleme and im wondering if there is any recovery possible. It must be fixable since some site ask core charge for replacement board.
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic Viera TC-L32U22 no picture
    grab a flashlight and shine it into the screen, the image may be there but the backlight not on.
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      You need to carry out some checks before you write off the main board. The power led is on so it looks like your standby voltage is working. Now you need to check that you have all the other voltages given on the power supply board .
      Manual available for download from
      • pr0cess0r
        • Jan 2011
        • 110
        I will test the tv for sound on all input but what i know is that the backlight is on but the standby led stay on. That why i think it is controlled by the mainboard and it dont post or something like this. i will try to find some service manual since there is no voltage on the pcb. All caps look good and they are rubycon.
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          I've pointed you to a link for the service manual in the post above.
          • pr0cess0r
            • Jan 2011
            • 110
            i got the service manual and they have TP listed but im not able to find them at all .
            I did some more testing.
            HDMI connected to PC and its detected by the computer but no picture.
            When i change input i get different backlight level.
            I whas not able to get sound with hdmi.
            and here are all voltage at the A03 connector.
            tv_on
            1=0
            2=1.8
            3=2.9
            4=.09
            5=5.98
            6=3.25
            7=2.32
            8=0
            9=18.54
            10=0
            11=12
            13=12
            13=0
            14=6.09
            15=6.09
            tv_off
            1=0
            2=0
            3=0
            4=0
            5=0
            6=0
            7=0
            8=0
            9=10
            10=0
            11=0
            13=0
            13=0
            14=6.09
            15=6.09
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              Can you post pictures of A03 connector and power supply board
              Is the connector a 16 pin connector?
              • pr0cess0r
                • Jan 2011
                • 110
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  The connector is labelled 1 - 16 in the 2nd photo but you only give 1 - 15 in your readings. Can you resubmit please 1 -16 since I don't know which one you have left out.
                  • pr0cess0r
                    • Jan 2011
                    • 110
                    1-16 is P2
                    1-15 is A03
                    i did some more testing i got sound working.
                    The screen is not black but more like dark gray like a tv that is on and have backlight but black picture. Id i disconnect LVDS cable i get same picture.
                    • pr0cess0r
                      • Jan 2011
                      • 110
                      look like
                      1=15
                      15=1
                      16 is empty
                      • Diah
                        • Feb 2013
                        • 6376
                        common, they ask you at first yours post to use torch light on the screen, you have dead back light of sure
                        • pr0cess0r
                          • Jan 2011
                          • 110
                          You see backlight
                          • Diah
                            • Feb 2013
                            • 6376
                            this is still nothings, use tourch light and go in menu first , and check gama brightness ...light it may values zero
                            • Diah
                              • Feb 2013
                              • 6376
                              you can do this as shown in manual
                              Self-check indication and forced to factory shipment setting:Produce TV reception screen, and while pressing [VOLUME ( - )] button on the main unit, press [MENU] button on the remotecontrol for more than 3 seconds.
                              • dick_barton
                                • Aug 2015
                                • 6643
                                • Wales
                                Can you find the following measuring points and give the results where it says TCONxxx
                                • pr0cess0r
                                  • Jan 2011
                                  • 110
                                  i alredy did this. i also did a firmware update from sd card... to me its 100% sure that back light is working properly. look like no lvds signal. is there any fuse on this signal i dont know.
                                  • dick_barton
                                    • Aug 2015
                                    • 6643
                                    • Wales
                                    I'm not sure at this point but the Tcon appears looking at the manual to be an integral part of IC8001 so perhaps this has suffered from poor solder connections and is one for the oven treatment.
                                    • Diah
                                      • Feb 2013
                                      • 6376
                                      this is only for mini lvds module..
                                      • dick_barton
                                        • Aug 2015
                                        • 6643
                                        • Wales
                                        Hello Diah, I cannot seem to locate anything relating to the Tcon board other than it being integrated within IC8001. Have I missed something?
                                        • FZG
                                          Panasonic AG-1000B VHS player with bad picture quality
                                          by FZG
                                          Hello!
                                          I recently got an old VHS player from Panasonic and just for fun I want to try to repair this device. It is an AG-1000B portable VHS player from 1990 and it has a problem with picture quality in playback mode.
                                          Picture in playback mode is very noisy and often loses sync but the still images are nearly perfect.
                                          I want to know, is this something that could be solved by recapping or is the video head likely gone?
                                          Also, what mechanism is this?
                                          Any feedback is appreciated!...
                                          05-06-2024, 07:16 AM
                                        • Bazfletch3
                                          Panasonic TH-65FX800A backlight LED's working but picture is very dark
                                          by Bazfletch3
                                          Hi all
                                          While I have quite a decent background in electrical & electronic troubleshooting & repairs, this is my first time stripping down an LCD TV for repair.... I have inherited a 3yr old Panasonic LCD which has a picture, but it is quite dark (too dark to be watchable - but still quite easy to see; I didnt need a torch to see it).
                                          I started by checking and trying to adjust all of the picture and backlighting levels, but that made little to no difference. I also did a factory reset.
                                          From there I envisaged that the backlighting wasn't working, however...
                                          01-08-2024, 10:18 PM
                                        • Tr0ll
                                          by Tr0ll
                                          Original T-con:
                                          First replacement T-con:
                                          10-07-2023, 07:48 PM
                                        • JJAAMM
                                          by JJAAMM
                                          Problem
                                          07-06-2023, 06:01 AM
                                        • mar1in
                                          Panasonic TH-55AS670A no picture no sound
                                          by mar1in
                                          I've got this Panasonic TV here with the following symptoms:
                                          * Standby Light is solid RED
                                          * Turning on using the Button on the TV (long press) would change LED to blinking GREEN
                                          * After a couple of seconds, LED is solid GREEN and without picture or sound.
                                          I've tried a couple of things before tearing it apart:
                                          * Resetting using various combinations of powerbutton and volume buttons pressing down while booting.
                                          * Activating Self Check according to service manual using IR Blaster (we have no remote unfortunately)...
                                          09-10-2023, 11:10 PM
