42LG500 stuck in standby then after being disconnected for a while works again
  • piccy
    • Dec 2014
    • 37
    • Ireland
    have a LG 42LG500 tv that went into standby a couple of days ago and just blinks 3 times bright red led when attempting to switch it on , have not used it for a couple of days and it was disconnected from mains supply it now switches on again , is this an eprom issue that i know some lg 's suffer from or an invertor board fault. The power supply seems ok voltage wise i will re check the invertor 24v
  • sordids999
    • May 2013
    • 2161
    • uk
    Re: 42LG500 stuck in standby then after being disconnected for a while works again
    Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
    • stylishconsultant
      un60j620dafxza - Samsung No Display Problem
      by stylishconsultant
      Hi All,
      Need help.
      I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
      So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
      problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
      might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
      09-04-2024, 03:26 AM
    • lepak06
      TV LED 4K Selecline 65S18 ( T.MS3458.U801) stuck in Standby mode
      by lepak06
      Hello
      I have an TV Led 4K Selecline 65s18 with mainboard T.MS3458.U801
      The TV is faulty with stuck in Standby RED LED. Can't power the TV.
      Before this problem , the TV stuck the picture with artefact , i unplug the AC cable and since the tv is stuck in standby .
      All voltage are OK on PSU and main board for regulator. I tried flash firmware 25Q64 with many dumps
      But the voltage on power button is 0.6V not 3.3V. When i press power button the voltage up to 0V. I tried to add 5V with Power Supply on 5V_STB and 3.3V on Power...
      01-12-2023, 01:43 AM
    • baglaivlad
      A1706 820-00239 - Works, but sometimes shuts off when the charger is disconnected
      by baglaivlad
      Hello everybody!
      Have in work A1706 820-00239 model. Originally no power, shorted PPBUS_G3H because of corroded C6403, C6404. Some water damage around this components, but nothing major.
      After replacing this capacitors the laptop came back to work, I reinstalled MacOS and had no issues until I started to test Type-C ports. Sometimes the laptop shuts off immediately when some action with Type-C ports performed (charger disconnected or USB device inserted/disconnected). I checked Type-C port flexes, they are okay, but I cleaned them anyway. I can't see any signs of liquid...
      11-20-2024, 08:14 AM
    • toty79
      Hisense LTDN50K220WSEU stuck in standby
      by toty79
      Hello to all friends of the forum and well found, here I am asking for your help and sorry for my translated English.
      As per Hisense tv title LTDN50K220WSEU stuck in standby
      PSU rsag.820.5687 HLL 4855WF
      Main rsag 7.820.5842
      I enclose the psu diagram, after the first routine checks I find myself with a regular standby voltage of 3.3v blue light on steady when the power button is pressed nothing happens, psu disassembled and bench checked ... forced ignition by sending a signal 3 , 3v on the SW and PWM2 pins the psu turns on and delivers all the voltages...
      05-01-2022, 04:39 PM
    • DynaxSC
      GIGABYTE GA-H110M-S2 - Stuck at Debug Code C2 - don't like Patriot Viper Steel RAM but works with G.SKILL
      by DynaxSC
      I discovered a strange behaviour of GIGABYTE GA-H110M-S2 board.
      General test conditions:
      - Tested with Core i5 6500 and Core I7 6700K - no difference
      - Default BIOS settings, but tried also altering several memory setting - does not change anything
      What is wrong:
      With BIOS F1 and F2 the board normally POST's and boots to Windows 11 with 2 x Patriot Viper Steel PVS416G440C9K RAM (4400MHZ, Samsung B-Die chips)
      When BIOS upgraded to anything above F2 (ie. F20-F27b) the board POST stucks after 3 Debug Codes on Code C2
      03-21-2025, 06:23 PM
