47 inch lg model 47lx6500 blacks out
Re: 47 inch lg model 47lx6500 blacks out
Are you talking about the V+?YES- They are wired together and they all jump to around 135 vdc and jumps little higher and lower and then settles down to 115 vdc and holds steady. Its the same with backlights plugged in or out. There is a power diode that goes from 115 steady voltage to backlight ckt' and it is steady at all times. A couple of filter cap are there but they are good. There is a ckt. that goes from pos. side and think it might be shut down ckt. Don't know for sure. A schematic would be a big help. Any thoughts?
1A/B/C (same for 2, 3, and 4) are the Cathode for the current return lines through the PWM control MOSFETs.
What do you get on all of those 12 pins?Never stop learning
Hi guys im working on this exact set, customer states watching tv backlight switched off.
so far i have stripped it down and removed lcd no visible burnt led (edge lit set 4 lots of leds) i have tested from v+ to each return wire on switch on all strips are the same about 131 volts. Whats odd the backlight has now turned on and stay on. I tried re booting the tv a few times what i have noticed though on boot up about 1/3 of screen leds top and bottom light up bright the other 2 thirds are lit but not as bright? then all of a sudden they go full brightness like the rest, could this be a power supply fault? drive on i presume is back light on which is 5 volts on every switch on (even if back lights fail it still is 5v) any help appreciated.
budm posted in post 12 this, so leds lighting like they do could this be normal on switch on?
This LG has this feature called LED Plus Technology:
From LG: LED Plus Technology
Tired of dark scenes or dull colors? LG's LED Plus technology provides even greater control of brightness through local dimming to deliver amazing clarity and color detail, as well as a more energy efficient TV compared to conventional TVs.
It has more than TWO LED strings, as you can see on the sub board, there are many PWM Controlled power MOSFETs for a bunch of LED strings to achieve local dimmimg.
budm also mentioned it has twelve strips it has (4 each strip has 3 sections)
link to psu used https://www.shopjimmy.com/lg-eay6080...ply-led-board/Last edited by vinceroger69; 12-10-2021, 12:15 PM.Comment
its a odd strip it probably has 30 leds on each strip (4 in set each on own heatsink) on the end of led strip is a connector with 4 wires on which then goes straight to the psu i will try and get a picture .
https://www.ebay.co.uk/itm/274739443...5c50%7Ciid%3A1Comment
Just been looking at this tv again each led strip has 66 leds broken into 3 sections hence 4 wires per strip I have tested all the sections using a led tester all draw, same voltage and amps.I have found a cheap psu/led driver board on ebay so going too try a board swap if that solves the issue I will use new board to fault find the original I will update the thread when it's fitted
.Comment
Just fitted the replacement power supply/led driver board the set seems to work ok now i have factory reset and retuned etc only thing i cant seem to get too work is anyrthing netcast based none of the apps work has netcast service ended now this set is a LG 47LX6900 2010Just been looking at this tv again each led strip has 66 leds broken into 3 sections hence 4 wires per strip I have tested all the sections using a led tester all draw, same voltage and amps.I have found a cheap psu/led driver board on ebay so going too try a board swap if that solves the issue I will use new board to fault find the original I will update the thread when it's fitted
.Comment
by L3gitHi everybody! I found a LG 4K 60 inch TV (Model: 60UM6900PUA) on the street but don’t know what’s wrong with it. There was no power cable and remote. I plugged it in with a power cable I found in my house that’s 125V 7A into an outlet. The TV did not turn on, don’t know if the power cable I used has any bearing on it. I wanted to know if it’s worth fixing, I don’t know how to solder by the way. Thank you for taking the to time to help me!...
by saman mawlodi have hp pro one 600 g4 with 3 long beep and 4 short beep power error
serial number : JPG947J18R
OLD BIOS...-
This specification for the Acer Swift Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Silver) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Silver) boardview and Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Silver) schematic. Our...09-06-2024, 09:30 PM
This specification for the Acer Swift Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) boardview and Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) schematic. Our users...09-06-2024, 09:30 PM
This specification for the HP ProBook 450 G5 + Essential 15.6-inch Case, Keyboard & Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G5 + Essential 15.6-inch Case, Keyboard & Mouse boardview and 450 G5 + Essential 15.6-inch Case, Keyboard & Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users...09-06-2024, 06:21 AM
- Loading...
