Monitor worth saving?
  • srilyk
    • May 2008
    I have a 19" Samsung monitor that I "inherited" from my dad.
    He gave it to me because the monitor would turn on for about 1 sec. and then turn off again. It would continually cycle like that, and my guess was that one or more capacitors in the power supply had gone bad (from my beginner's knowledge on the subject).
    Well today I finally got around to attempting to open it up & all that good jazz.
    I found 3 capacitors with bulging tops (which I'm told means they're bad). I've desoldered and removed them. I have 2 x 820mF 25v caps, and 1 x 470mF 25v cap that are the ones I'm fairly certain are blown.
    Here's a shot of the board, minus the 3 caps:
    My question is this: noting the somewhat "burnt" quality of the board, is it worth replacing the caps, or is it likely they (or other components) will blow as well?
    Thanks for any help! (also, would it be more worth it to pick up some caps online, or just swing by my local Radio Shack ?)
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Monitor worth saving?
    "burning" looks normal
    definitely worth saving
    caps may be not the only problem in lcds
    need low esr caps, not available at radio shack
    • srilyk
      • May 2008
      What other things should I look for?
      Is there any particularly good source for low esr caps?
      Thanks!
      • Wizard
        • Mar 2008
        • 2296
        Fix it with new caps!
        Samsung monitors are pretty good for what they are.
        Cheers, Wizard
        • starfury1
          • May 2006
          • 1256
          Generally speaking
          For the price of some decent caps its worth fixing.
          mostly caps are the issue, although inverter transformers have been known to pack it in. (also other faults have been known depending on brand model)
          Be careful as that has High Voltage on that PCB and also directly connects to your Mains supply system
          Make sure you put the caps in the right way round too.
          As willa said looks like (unfortunately) fairly normal cooking of PCB.
          there can be other issues of course but "caps only" are a good bet so go for it.
          Cheers
          You step into the Road, and if you don't keep your feet, there is no knowing where you may be swept off to." Bilbo Baggins ...
            by momaka
            03-15-2023, 10:17 PM
          • black6host
            Replacement caps for Samson Resolv studio monitor 65A Amp board.
            by black6host
            Good day!
            I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
            I'm going to replace the caps and I'll be the first...
            02-06-2024, 08:22 PM
            by momaka
            03-12-2025, 03:42 PM
          • eryjus
            by eryjus
            05-10-2023, 11:21 AM
            Wise Wing F199 19'' LCD monitor - recapped
            by momaka
            Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
            I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
            When I saw the Craigslist post, I wasn't...
            08-24-2020, 10:58 AM
