Panasonic TH-50PX80U SC board troubleshooting
  • braxton
    • Nov 2009
    • 146
    Hi I have this Panasonic plasma TV that appears to have a bad SC board based on my troubleshooting (7 blinks). As it is an old TV, I was hoping I could repair the board (as opposed to trying to replace it and hope for the best).
    Can anyone point me in the right direction as to which part(s) commonly fails on this particular board? The board is a TNPA4393.
    Thanks for any insight...
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Panasonic TH-50PX80U SC board troubleshooting
    Do you know how to check for S/C ?
    • braxton
      • Nov 2009
      • 146
      Sorry I don't know what s/c is (unless you mean SC??
      I have a digital multimeter and am OK with soldering but am not an electronic tech.
      • braxton
        • Nov 2009
        • 146
        If you are referring to the SC board, I can give you what I have tried. First I picked up the set with 7 blinking lights and know nothing else about the history of the set. First, I removed the cables to the SU and SD boards and still had 7 flashing lights. Next I removed the cables from SC2 and SC20 connectors on the SC board and then the red light stayed solid -no more blinking (still blank screen). This would seem to suggest the SC board to me.
        • tech2014
          • Aug 2014
          • 807
          S/C means short circuit
          • braxton
            • Nov 2009
            • 146
            Yes I can check for short circuit with my multimeter. So far I know that the 2 pins on SC2 are not shorted. What are other obvious short locations?
            • Alastair E
              Chief Womble
              • Mar 2013
              • 1963
              • U.K.
              PX80 SC boards are extremely reliable.
              As such, they tend to be very cheap--and as they are fairly old--Plentiful.
              Might as well just buy another...
              TELEFIX
              • braxton
                • Nov 2009
                • 146
                OK thanks for the input. Based on my troubleshooting described above, is the likely culprit an SC board or could it be something else - like the A board? Your reliability comment has me worried now.
                I just hate to be throwing money into an old 720p tv- I would prefer to fix for under $20 if possible
                • Alastair E
                  Chief Womble
                  • Mar 2013
                  • 1963
                  • U.K.
                  fully disconnect and remove the buffers. you must remove all the large screws to the sc from buffers--best take 'em completely out of set.
                  with everything else connected, fire it up.
                  If it runs with no blink--the buffers are faulty.
                  TELEFIX
                  • braxton
                    • Nov 2009
                    • 146
                    With SU and SD removed I get 7 blinks
                    • braxton
                      • Nov 2009
                      • 146
                      I know there is a common transistor/mosfet repair for the TH-42PZ77U SC board so I was hoping there was a common check and repair for the SC board from the TH-50PX80U series as well
                      • braxton
                        • Nov 2009
                        • 146
                        I see shop jimmy has the SC board but I'm looking at >$80 Canadian which is more than I'd like to spend, especially since it might not fix the problem.
                        • braxton
                          • Nov 2009
                          • 146
                          I found a guy locally that had a compatible used SC board but it displays exactly the same symptoms (7 blinks with buffer boards disconnected, solid red with SC disconnected). He mentioned it was pulled from a TV with bad buffer boards, so his was likely a bad SC board too I'm guessing.
                          Any suggestions as to where to start looking for shorts on my SC board?
                          • Alastair E
                            Chief Womble
                            • Mar 2013
                            • 1963
                            • U.K.
                            Any/All the heatsink mounted parts and the larger SMD transistors/diodes on the board.
                            TELEFIX
                            • tw2005
                              • Oct 2011
                              • 6458
                              you can't run these with either sd/su removed or they 7 blink
                              Read this document as they have the correct procedure
                              • braxton
                                • Nov 2009
                                • 146
                                Thanks for this! I was unable to find the PX80U procedure so I used the closest troubleshooting guide I could find. Looks like I will need to re-test...
                                • braxton
                                  • Nov 2009
                                  • 146
                                  So now I added the jumper from buffer floating ground to SC L801 coil and I get the same result (7 flashing lights with only both buffers disconnected and jumper in place, bot solid red when SC 2 and SC20 cables disconnected.
                                  Still points to a bad SC board, although the other board I tested may be OK as I didn't use the jumper when testing that one.
                                    by sam_sam_sam
                                    After all of...
                                    07-13-2024, 08:14 PM
                                  • canadaboy25
                                    Panasonic TC-P54VT25 No image. A or D board?
                                    by canadaboy25
                                    I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                                    The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
                                    I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                                    01-17-2021, 01:06 AM
                                  • howardc64
                                    by howardc64
                                    07-24-2025, 05:17 PM
                                  • dajoker
                                    Panasonic th-p50s10d - blinky red, SC board go boom
                                    by dajoker
                                    My old plasma died when one night recently. When I got to it it was giving a 3.3v sos (3 blinks).
                                    I chased my way through the PSU, and a board, with no results.
                                    Replacing a few bulged caps in the PSU, I eventually got to the SC board that had piles of shorts, a quick cheap replacement from china and the tv powers up again, except
                                    I only have the right half of the picture.
                                    Left half is completely blank.
                                    now the c3 board running this side of the screen has its 3.3 and 5v onto the buffer ic and its got the 60v, so that all seems good.
                                    all the other voltage rails...
                                    09-24-2024, 04:39 AM
                                  • stecos
                                    Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                                    by stecos
                                    Hi everyone!
                                    For my passion for technology I'm now collecting several...
                                    11-28-2022, 11:39 AM
