Magnavox 46me313v/f7 will not turn on
  • junkmale172
    • Nov 2012
    • 41
    • usa
    Hello forum, I have a magnavox that has the standby light but will not turn on. I thought it was a power supply problem as I heard a buzzing noise coming from some diodes, but the buzzing noise is only there when main board is connected via ribbon cable. Every connection to main board is disconnected, just main board and power supply. I tested outputs on main board and will give readings.
    0
    0
    .458
    3.279
    .216
    3.153
    .179
    3.2
    0
    0
    0
    0
    0
    0
    0
    12.29
    12.29
    12.29
    12.29
    0
    21.19
    21.19
    21.19
    21.19
    The board is in stock at shopjimmy, and before I ordered just wanted to check with the forum to see what everyone else is thinking.
  • junkmale172
    • Nov 2012
    • 41
    • usa
    Re: Magnavox 46me313v/f7 will not turn on
    A
    • junkmale172
      • Nov 2012
      • 41
      • usa
      B
      • junkmale172
        • Nov 2012
        • 41
        • usa
        C
        • junkmale172
          • Nov 2012
          • 41
          • usa
          Fix update. Ordered main board from shop jimmy, tv turns on, but composite video was black and white, and there was a static noise coming from speakers. Called shop jimmy, and they sent out another board, plugged this one up, and video worked fine, and sound was great.
          • pajdek
            Lenovo Y700-17ISK turn on and off
            by pajdek
            Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
            09-20-2023, 02:49 AM
          • RdeveLabs
            MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
            by RdeveLabs
            To all the members here...
            Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
            So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
            05-05-2025, 04:59 AM
          • robante15
            Acer Aspire 4520 won't turn on after reboot
            by robante15
            Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
            It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
            The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
            If I remove the...
            04-06-2024, 06:50 PM
          • masoksian
            Dell latitude e7470 not turn on .power buton on off and Run Power problem
            by masoksian
            I am dealing with the problem of turning on and off my Dell e7470 notebook.
            The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
            The system does not turn on, there is no post.
            I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
            The problem continues in the same way.
            I tried to turn on the Fn key, nothing came to the screen....
            02-15-2025, 12:08 PM
          • dqtech
            lenovo x240 nm-a091 wont turn on
            by dqtech
            i got this laptop with no power issue....i flashed the bios and laptop can turn on and use normally....but when i shut it down and rest for few minute (2-3 minutes), it wont turn on....i have to flash bios again...any idea what is the problem?...when i shutdown and suddenly press power button to turn on, it will turn on normally....problem happen when i rest the laptop 2-3 minutes after shutdown, it will not turn on....i need to flash bios again
            board number VIUX1 NM-A091 REV:1.0...
            02-07-2024, 01:57 AM
