Sony KDL-46S4100 no pic or sound help.
  • snme
    • Feb 2016
    • 26
    • AU
    #61
    Re: Sony KDL-46S4100 no pic or sound help.
    Originally posted by ivtec
    Hi guys; Update on Sony Stripes on the LCD screen,i don't think this will make any difference but i'd like you opinion.
    The later pictures that I saw of your chassis still exhibited a similarly wide region of vertical outage, the stripe including not quite darkness at the sides with a centered bright region of rubbish.
    I do hope that you can find some pressure points on the bonds to help the situation.
    • ivtec
      • Dec 2008
      • 1967
      Thanks snme; i have tried this door sealing tape, on all the flex no change,
      it seems more pressure makes it worse,so i think this Panel has no repair solution,also i could get another sony same panel model like this but its' a risk might end up with same panel issue,this guys sells this sony 46SL140 that has same Panel assembly, but he says it take 40 minutes to turn on.
      for 149 bucks,but as i say it's risky.
      http://www.ebay.com/itm/SONY-Bravia-...item3f5c2ada05
      http://www.homedepot.com/p/Frost-Kin...516H/100090883
