LG LED 50LB5610: Display blinks
  • PatrickSaw
    • Nov 2015
    • 20
    • Spain
    Hi there!
    I have here a brand-new LG 50LB5610, with no warranty due to missing invoice... Well...
    Fault: Power up, and display start with the flickering. About 2 seconds picture OK >> 2 seconds screen black >>2s picture OK >> 2s screen black...
    I measured the voltage out to the backlight, and it's innestable, but PSU is OK (I have two identical PSU, and I have checked it). So I think I need replace the main board.
    Do you think main board is faulty? Or could be the backlight?
    Thanks in advance!
  • PatrickSaw
    • Nov 2015
    • 20
    • Spain
    Re: LG LED 50LB5610: Display blinks
    Any ideas? I accept even stupid ideas
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Lose connection with in the Led strips very common, your going to need to take the Lcd module apart to the backlight and get us some images of the array.
      • PatrickSaw
        • Nov 2015
        • 20
        • Spain
        But I have measured LED+ LED- in the PSU, and it has unstable voltage. And it must be stable... isnt it?
        • Diah
          • Feb 2013
          • 6367
          unstable voltage mean you have shorted LED...
          • PatrickSaw
            • Nov 2015
            • 20
            • Spain
            You were right!
            I have disassembled and checked the display and strip LEDs: a LED segment is faulty. So now I need replace that segment, because I suppose it's impossible to fix a strip LED...
            Thanks very much to both! I would have never found this fault without your help.
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              No it is easily possible check this out:
              https://m.youtube.com/watch?v=Bf5T2wwtydY
              • PatrickSaw
                • Nov 2015
                • 20
                • Spain
                Hello again.
                Great video. But I cant find a Led for the strip... I have read your advice, about not short the faulty led. You talk about replace the Led with a 1w SMD type, or sub it with a resistor or diode. Could you tell me a little more about that? I have doubts in type of diode, or what resistance value use.
                Thanks again in advance!
                • Diah
                  • Feb 2013
                  • 6367
                  Hello again.
                  you can buy one lot 100 pieces from China, at aliexpress.com for just less 3 USD include post
                  3528 2835 SMD LED 1W LG Cool White
                  Model Number: LATWT470RELZK
                  Brand Name: LG
                  Forward Current:400mA
                  lumens: 100LM
                  Forward Voltage:3.05-3.65V
                    Can we see the pictures of the LED strips in your TV?
                    • PatrickSaw
                      • Nov 2015
                      • 20
                      • Spain
                      Yes of course! It lights on 4-5v.
                        Ah yes, those are commonly failed LED type.
                        LG INNOLUX LEDs
                        Luckily it is Back-lit not Edge-lit.
                        Once you get it fixed you should turn down the Backlights level in the on screen user menu as low as possible to extend the LED's life.
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          Why is it lucky ? You can sub them Leds with 0.5w ultra bright SMT type off Ebay.
                            More room on the backlights LED strip than the Edge lit strip which LEDs are crowded together.
                            I would go with 1W, 0.5W is less than 200 mA current limit, some of these strips are driven with more than 200mA, not much room for margin with 0.5W LED.
                            • PatrickSaw
                              • Nov 2015
                              • 20
                              • Spain
                              LG INNOLUX LEDs
                              You mean I could replace the faulty LED only with a resistor?
                              Roger that.
                              • ReeceyBurger123
                                Never Give Up !
                                • May 2014
                                • 7325
                                • Britain
                                Ahh I see, yeah I agree replacing edge lit type leds is very hard. I have a youtube video uploading now about me repairing this type of Led strip. Will create a tread on it tomorrow.
                                • ReeceyBurger123
                                  Never Give Up !
                                  • May 2014
                                  • 7325
                                  • Britain
                                  Roger that.
                                  Yes I think user Tom66 uses a 0.5w 2.2 ohm type to sub a bad led. I will get the thread for you.
                                  • ReeceyBurger123
                                    Never Give Up !
                                    • May 2014
                                    • 7325
                                    • Britain
                                    Here is the thread:
                                    https://www.badcaps.net/forum/showth...ghlight=Ves315
                                      400mA of driven current! made to fail.
                                      • ReeceyBurger123
                                        Never Give Up !
                                        • May 2014
                                        • 7325
                                        • Britain
                                        Yep
