Samsung model LN52A750R1FXZA Power cycling
  • bbsimons
    • Jan 2016
    • 6
    Has anyone seen and fixed this problem on a Samsung LN52A750R1FXZA? I have come across two different issues with these TV's on these boards. One was the capacitor issue with the bulging capacitors. I have replaced the capacitors with no luck and the problem persist. The TV will go into a constant loop of powering off and powering on. Only way to stop it, is to unplug the power.
    I also came across this thread,
    https://www.badcaps.net/forum/showthread.php?t=32061, which discusses the same issue on many Samsung TV's about the same age. All were fixed by changing out the c102 Tantalum Capacitor. Thought that I found my fix for sure; however, my main board is slightly different and doesn't have that capacitor.
    I have posted two different pics (front and back of my board). Anyone have any ideas with this specific model?
    Thanks,
    Bobby
    Re: Samsung model LN52A750R1FXZA Power cycling
    Try heating those NEC-TOKIN caps (those are the same type of failed cap as used for C102).
    Pictures provided bu shopjimmy.
    • bbsimons
      • Jan 2016
      • 6
      I heated the chips as recommended. This worked for about 4 days. The TV started cycling again over the weekend. I think I will start replacing these and see if I can make the fix more permanent.
      • eblaize
        • Feb 2016
        I'm beginning to have issues with this same model not powering up and when it does I sometimes get a screeching sound accompanied with a distorted green image. Going to begin to look into it this weekend.
        • braxton
          • Nov 2009
          • 146
          yes please continue to update this thread and let us know if any bad caps are found on the main board...
          I have a ln46a650 that also does not have C102, but occasionally power cycles (accompanied by a glitchy image during the power cycles)
            For ref:
            https://www.badcaps.net/forum/showth...228#post631228
            • braxton
              • Nov 2009
              • 146
              Originally posted by budm
              Thanks!!! I will order some caps for replacement...
              • Dapper Dan
                • Apr 2016
                • 3
                SAMSUNG BN94-01658E C102 location number is under IC101 if you are looking for that first, good luck.
                The kit from ShopJimmy is a ceramic replacement cap with no polarity which can be installed in either direction.
                Shopjimmy offers no support at all!
                IC1203 - STA335BWS (SSOP-36) I could only find this on Ebay!
                IC101 - (MP2363DN) Digi-key P/N 1589-1366-ND
                C102 - 47uF 10V Tantalum Capacitor Digi-key P/N P16230CT-ND
                I used an iron to mount C102 after I mounted IC101 due to size, worked nice for me!
                Hope this will help someone!
                • high-tech
                  Samsung UN55F7050AFXZA ver. TD01 power cycling
                  by high-tech
                  Hello everybody, I could use some help on this one... It's got me guessing...
                  I took pictures of all the boards and the pin out of the connector on the power supply that goes to the main board... I measured all the pins in relation to chassis ground, here are the result.
                  (B13v)1. 12.7 volts cycling (Vamp) 2. 12.7 volts cycling
                  (B13v)3. 12.7 volts cycling (PWM5) 4. 1.0 volts cycling
                  (OD_LE)5. 2.8 volts cycling (PWM4) 6. 0.9 volts cycling
                  (OD_ON)7. 2.8 volts cycling (PWM3) 8. 0.9 volts cycling
                  9. ground (PWM2) 10. 0.9 volts cycling...
                  09-15-2020, 03:39 PM
                  HP ProBook 640 G1 Base Model Notebook 600 Specification for Upgrade or Repair
                  This specification for the HP ProBook 640 G1 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 640 G1 Base Model boardview and 640 G1 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                  09-06-2024, 05:27 AM
                  HP ZBook 14 G2 Base Model Notebook 14 Specification for Upgrade or Repair
                  This specification for the HP ZBook 14 G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 G2 Base Model boardview and 14 G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                  HP EliteBook 840 G2 Base Model Notebook 800 Specification for Upgrade or Repair
                  This specification for the HP EliteBook 840 G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G2 Base Model boardview and 840 G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                • valvashon
                  Samsung UN55FH6030: random power cycling
                  by valvashon
                  Samsung UN55FH6030, perfect size for my office and does OTA well but isn't a smart TV. That's OK because I am a TV station engineer and only need it for OTA monitoring.
                  About a month ago it started power cycling itself once or twice a day and now it's nearly continuous once it's been on for a few minutes. Changing channels would really start it cycling and it would take several minutes to stabilize but now it's just doing it almost non-stop without changing channels.
                  Once I disconnected the antenna I found that I could change channels with no issues. My guess is...
                  10-20-2023, 09:59 AM
