LG 50pk950 psu issue
  • seraph
    • Jan 2016
    • 8
    • newzealand
    Hey guys first subject thread for me here so please bear with me! I'm not super familiar with electronics, but I'm learning so here goes!
    I picked up an lG 50pk950 last week, pretty cheap not working thinking it would be a good project to undertake, I've read around the net trying to isolate the problem and I believe its the psu.
    If I turn it on after being unplugged for a while it'll power up but at most 20 seconds but then it clicks off and only click the relays when trying to turn on. Same 3 clicks when everything is disconnected except the ac to psu. I Have checked the 3 10 ohm ceramic resistors and they're fine, D304 is fine off the board, f302 is fine. Does ic301 always take out d304 and f302 when it goes??
    Caps all look fine (unsure how to test) all other ceramic resistors read fine.
    Anything else commonly go wrong on these boards?
    Thanks!
  • sordids999
    • May 2013
    • 2149
    Re: LG 50pk950 psu issue
    Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
    • Hamie
      • Apr 2014
      • 1383
      If the TV powers on occasionally its not IC301.
      It's more likely ic701.
      Use freeze spray on ic701 and see if it turns on.
      • seraph
        • Jan 2016
        • 8
        • newzealand
        I wish I could put up photos, but since i slammed my phone in a car door unfortunately I'm cameraless!
        But the board is this one
        Freezing ic701 didn't change a thing :/ still the usual. Initial power up gets to no signal, then switches off and click click click...usually haveto wait atleast a day before it'll get as far as no signal again. Totally perplexed.
        • sordids999
          • May 2013
          • 2149
          Possible fault:
          All supply voltages will come up then die
          Intermittent going on and off and clicking
          will work for 20 mins then will go off and start clicking*
          If heating/cooling ic701 makes no difference*
          check R103,R104,R105,R106,R107,R108,R109,R110,R111,R112, R113
          hope this may help
          • seraph
            • Jan 2016
            • 8
            • newzealand
            Originally posted by sordids999
            Possible fault:
            hope this may help
            None of them are dead, what are the values supposed to be?
            • ljintexas
              LJinTexas
              • Jan 2015
              • 669
              Maybe try some heat ?
              • sordids999
                • May 2013
                • 2149
                Originally posted by seraph
                none of them are dead, what are the values supposed to be?
                r103,r104=240k
                r105,r106=150k
                r107=100k
                r108,r109,r110=680k
                r112=620k
                r113=560k
                • seraph
                  • Jan 2016
                  • 8
                  • newzealand
                  r103,r104=240k
                  r105,r106=150k
                  r107=100k
                  r108,r109,r110=680k
                  r112=620k
                  r113=560k
                  r103; 215k
                  r104; 225k
                  r105; 145k
                  r106; 146k
                  r107; 99.8k
                  r108; 590k
                  r109; 530k
                  r110; 590k
                  r112; 551k
                  r112; 455k
                  Obviously some of these are looking a little low, likely to be causing an issue?
                  • seraph
                    • Jan 2016
                    • 8
                    • newzealand
                    r103; 215k
                    r104; 225k
                    r105; 145k
                    r106; 146k
                    r107; 99.8k
                    r108; 590k
                    r109; 530k
                    r110; 590k
                    r112; 551k
                    r112; 455k
                    Should replacing these solve the issue??
                    • ugamazing
                      by ugamazing
                      12-17-2024, 07:05 PM
                    • Simone Vergani
                      Alienware 15 R2 Service Tag: DL7NN32 ISSUE (Battery is not charging)
                      by Simone Vergani
                      I'm experiencing an issue with my Alienware 15 R2 (Service Tag: DL7NN32). The laptop works perfectly when connected to the AC adapter — it powers on and functions normally. However, the battery does not charge. If I disconnect the DC adapter, the laptop shuts down immediately, as the battery is at 0%. I have replaced the battery with a new compatible one, but the issue persists. I also replaced the AC adapter with a compatible one, but the battery still doesn't charge.
                      To assist with troubleshooting, I'm attaching two power circuit schematics:
                      • Power
                      03-05-2025, 02:25 PM
                    • wizard13
                      Dynabook Satellite Pro C50D-B-100 - BIOS Issue, Black Screen
                      by wizard13
                      I am experiencing a BIOS-related issue with my Dynabook Satellite Pro C50D-B-100. When I power on the laptop, the screen stays black, and there is no response from the system. I suspect a corrupted BIOS.
                      I have checked the forum and the available documentation but could not find a solution specific to my issue.
                      • Brand & Model: Dynabook Satellite Pro C50D-B-100
                      • Part Number (P/N): PYU13E-00C00PFR
                      • Serial Number (S/N): 22028896H
                      • System Configuration (SC): A1PYU13E1127
                      • Motherboard Model: IP3_ACN16_MB_V21_20211222A
                      • Power Input: DC 19V –
                      02-28-2025, 02:43 AM
                    • Titus6
                      LG OLE65C1 Stand-By issue
                      by Titus6
                      I bought an OLED65C1 refurbished TV back in 2022 from a shop. The TV is awesome, this is my first OLED and I really love it.
                      However I have an issue with the TV since the end of last year. I noticed when my TV is in Stand-By, sometimes the LED goes off then comes back on. When do so it seem periodical. It only goes away for 1-2 seconds, than comes back on. The TV NEVER turnes off, while it's on, so it's not overheating issue or electrical power issue.
                      I bought a service remote (MKJ39170828) and checked the menu 3. Power On/Off Status. I took...
                      01-31-2025, 04:01 PM
                    • Mirenia
                      Acer Helios 500 (PH517-51) - unexpected reboots when laptop is warm (cold solder joint issue?)
                      by Mirenia
                      got an Acer Helios 500 Laptop (PH517-51) for diagnosing with a strange issue:
                      The laptop runs for a while (1-2 hours, sometimes less) and then suddenly shuts completely off, like someone pulled the power cord and restarts immediately after on its own.
                      If this happened once, then the laptop only runs for a few minutes until restart.
                      This happens regardless while staying in windows or uefi or in a linux environment.
                      At first I thought of a normal overheating issue, but as I monitored temps with HWInfo64, nothing seems very hot.
                      01-05-2025, 05:15 PM
