Dell plasma question
  • Rmasters3
    • Mar 2010
    • 126
    Picked up a 10+ year old Dell plasma about a year ago, and fixed it with some new caps in the power supply. Just recently it's begun to act up--the lower half the screen goes black.
    This is usually after extended use--1 to 1 1/2 hours. It will flash back and forth with the picture occasionally returning. On/Off doesn't affect it.
    Before I get into it--anyone have suggestions as to what to look for? I'm guessing some solid state device is overheating, but if there a common cause knowing would help.
    Re: Dell plasma question
    It would depend on who made the plasma panel for this unit, but it would likely be a controller board, Y-buffer or X-address board failure. Since it is intermittent, you may be able to locate the exact intermittent part with hot air (a standard hairdryer does a decent job)
    • whiz62
      whiz62
      • Dec 2013
      • 242
      • usa
      I have a Dell with same symptom. I replaced some caps on power board about three years ago and then the bottom going black started a short while later. i could tap on back lightly and would straighten up. it is in garage now. when i get time i will dig into it. acts like a loose connection. it is a 43" samsung panel.
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • Akhlz001
        by Akhlz001
        09-20-2025, 07:15 PM
      • Mots06
        Old Dell E5400 Laptop ( Purchased in the year 2008)
        by Mots06
        Hi, I'm unable to find the motherboard number (PPID number) or the board view for this old laptop. My laptop won't start, and when I enter the serial number on the Dell website, it says the number is invalid. The sticker on the bottom is unreadable because it has faded over time. Unfortunately, I'm unable to start the laptop to use the power cell or explore other options.I needed the CMOS Cell & it also seems the Laptop will not start now because of the power switch issue, which is yet to be detected.
        07-19-2025, 01:56 AM
      • master3112
        by master3112
        07-29-2025, 01:55 PM
        Dell Thunderbolt Firmware
        by SMDFlea
        Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
        Some models have a choice of 2 different firmwares, it depends on the dell SKU.
        The SKU is in brackets (****)
        EDIT: NVM65...
        01-26-2025, 06:22 AM
