Sony Bravia KDL-46EX723 PSU Dead, No Standby
  • martyparish
    • Dec 2012
    • 313
    Hi folks,
    it's been a while since I've posted on this great resource! FYI I have exhausted myself searching and testing but still need some assistance please.
    The original situation: It started as a 5 blink error code, which means TCON, Panel or HWR(from service manual). I tried reseating the LVDS cable and nothing changed, then I disconnected the two ribbons that go from TCON to Panel and viola!! The TV came on with green LED lit and backlights lit.
    So I tried again with one of each panel ribbon connected and with the left one connected it was 5 blink error and with right cable connected the TV came alive.
    The situation NOW: The TV was sitting there on and I was testing the TCON fuse voltages and all of a sudden it turned off(I am 99% sure I didn't short it out). Now the PSU is DEAD!!
    There is zero power on the secondary connector pins including STBY.
    The main filter cap is getting ~170v(USA 120v mains).
    I'm suspecting the standby IC cct but not sure how to go about testing to be sure. The IC is:
    MIP2H2
    No datasheet available but there is a cct here: http://www.irantk.ir/Power_IC/irantk_Datasheet/MIP2H2_Schematic.pdf
    Would any of you kind folks be able to help me proceed?
    First, do you think it's a bad panel and I should just scrap my efforts? Or maybe it's tcon(cheap) and I should pursue fixing the PSU(expensive)?
    Much appreciated! Pictures attached.
    Marty P
    MD, USA
  • martyparish
    • Dec 2012
    • 313
    Re: Sony Bravia KDL-46EX723 PSU Dead, No Standby
    UPDATE: Standby 3.3v is THERE... Not sure if it was my oversight or maybe because it was sitting in the sun for a while. Still no front led or relay click. Hope I didn't kill the main board...
    I guess the next test is manually trigger BL_ON?
    Every pin on BOTH connectors reads 0v except STBY3.3.
    Last edited by martyparish; 01-29-2016, 08:35 AM. Reason: added measurements + legend pic
    • martyparish
      • Dec 2012
      • 313
      One more update: I applied voltage to POWER ON via 470ohm resistor and STBY3.3v. This fired up the PSU. I heard the relay click and most of the 12v pins came on.(tcon vcc did NOT come on but assuming because I need to also apply 3.3v to TCON ON)
      Is it a fried main board?
        The commands to the power supply board are generated by the main board, so something on the main board is at fault to not send the command signals or it is locked out due to error.
        Is the AC_OFF DET at 0V? It should be 3V or more for normal operation.
        • martyparish
          • Dec 2012
          • 313
          Thanks Bud. I've checked all the fuses(tiny!) that I could locate on the main board and they checked out.
          Did you happen see in the original post about the original problem? Was wondering what you thoughs were on whether it's a bad panel(tab bonds?) or just bad tcon.
          Main board= $125
          TCON=$40
          probably not worth it eh?
          • tvguy12012012120
            by tvguy12012012120
            02-07-2025, 05:13 PM
          • androripara
            Sony Bravia 55HX820 - 4 times blinking red standby led
            by androripara
            i am trying to repair a Sony KDL-55HX820 led TV which is throwing error code 4 (standby led flashing four times).
            I followed the troubleshooting flowchart at page 69, and between pin1 and pin7 of CN6002 i am reading 1.91V so i guess i can rule out the B Board as the culprit.
            Before ordering new G* Boards (by the way, should i change both? it is not specified in the manual) i wanted to try and do more advanced troubleshooting since i've read in other threads people resolving their problems on the 46/55 HX 820/823/825 models by replacing the Samsung led...
            10-19-2023, 05:16 AM
          • piposarcade
            Samsung UN50KU6300 dead no standby led
            by piposarcade
            01-04-2024, 01:33 PM
            Greetings to all, a while ago my TV was dead, it didn't turn on and the standby light was off, the next day it is working. But these days it no longer wants to turn on, I did some troubleshooting, I disconnected the main board, I checked the voltage on the backlight and there is 400 DC, when I connect it again the main board the voltage drops, in all that troubleshooting, miraculously the standby light comes on and the TV works. After an hour I check and test, I turn on the TV, the Stanby light flashes 3 times and it...
            05-22-2024, 02:07 PM
          • brithepi2k
            Sony KD-65XE8596 no standby light
            by brithepi2k
            I’ve got a Sony KD-65XE8596 here that has no standby light coming on. I’ve tested the power board with the test meter, the TV needs 3.4 for the standby but only getting 2.4. Anything that I can change/check on the board to get it working? Pictures of the board are included.
            cheers...
            09-06-2025, 02:22 PM
          • SkishyIshy
            Sony Bravia XBR-65x900f: No Power, No Standby-light - however 3.3v STBY is present
            by SkishyIshy
            Hey All,
            I have a Sony 65x900f that I purchased cheap because of a no-power issue.
            I assumed that because there is no standby light visible, it would be an easy fix - however upon opening up of the unit I can confirm that the 3v3 standby voltage is making it's way from the power supply to the main board. I'm a little confused as to why there is no standby light.
            I am firstly wondering if anyone has this model of TV, or has worked on one and can give me some insight. I have tried to find a service manual for this model, to no avail - and would really appreciate...
            03-17-2021, 11:44 AM
