RLCDV3282A-B Turns on then off with t.rsc8.10b 12305 main
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8352
    Re: RLCDV3282A-B Turns on then off with t.rsc8.10b 12305 main
    freeze the eeprom and turn the TV on.
    • dcapper
      • Dec 2013
      • 496
      I don't have a can of air here. I'll go get some this weekend. I didn't expect to come to my vacation home and have to fix 2 tv's. Oh well. Part of playing the game I guess. Thanks for the help. I'll post my findings.
      • dcapper
        • Dec 2013
        • 496
        I ordered this main board from shop jimmy. It was hard to find a 32" main board that had all the dvd connectors. I could have unsoldered mine connectors and solder them on the new board but this board was cheap enough to try. My RCA tv will become a Sceptre. At first I was concerned that the main board I ordered is for an LED but then I realized, the psu is what feeds the back light board. I shipped it 2-day so it should be here on Monday. Going to get the compressed air tomorrow to try anyways. Always useful to have.
        http://www.shopjimmy.com/sceptre-1e2...-e325bd-hd.htm
        • NanoTesting
          Lenovo Ideapad 15IIL05, turns on and off with charger BUT works by injecting 20v after main mosfets
          by NanoTesting
          I got a 15-IIL05 that failed to turn on BUT IT DID TRY TO TURN ON and then turned off after 30+- seconds, i disassembled it and found a screw loose inside the case.
          With charger it turns on, fan spins but gives no image.
          Tested main mosfets no short, tested 3.3v,5v,DRAM, CPU etc and they were present.
          Reflashed BIOS, same problem.
          Replaced both main mosfets.
          Checked main mosfets again and i noticed that they closed once the laptop shut down, so i decided to bypass them and used a bench PSU to check how much power the laptop was drawing while trying to turn on, 20v@3A,...
          10-30-2024, 10:48 PM
        • cheeky2
          by cheeky2
          05-25-2024, 03:27 AM
        • Dani_2024
          by Dani_2024
          10-28-2024, 05:06 PM
        • reset1986
          MacBook A1278 main 820-2530b not charge, it turns on only with battery
          by reset1986
          hi, I have this macbook that works correctly with battery inserted, if I connect the power supply the light turns green but it does not charge, if I disconnect the battery and connect only the power supply the light turns green and the mac enters the ignition loop 4/5 sec, turns off and repeats itself,
          on the motherboard there are no traces of liquid or damaged components,
          I tested the 3.42 and they are constant both with power supply and with battery,
          advice on what signs I can start checking?
          the power supply indicator light never turns orange,
          power...
          10-26-2021, 02:46 PM
        • ygorsan
          by ygorsan
          🧩 Problem Summary:
          • I
          07-28-2025, 08:34 AM
