LG 47ln549c
  • Jonny g
    • Jan 2016
    • 13
    LG 47ln549c
    Hope someone could help me, i had the backlight fail on my LG. I had the LEDs refurbished and now the back light works fine, all leds lit.
    The problem i am now having is i can see the lights on the screen and it seems to be all of them, this never happened before.
    The guy that repaired my leds said i put the filter sheets the wrong way round, so i have been swapping them and still seems to be the same issue.
    So how do i fix this light bleed and what is the correct order for the filters.
    Cheers
    Jonny
  • sordids999
    • May 2013
    • 2155
    Re: LG 47ln549c
    Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
    • Alastair E
      Chief Womble
      • Mar 2013
      • 1963
      • U.K.
      Re: LG 47ln549c
      Most likely you've put the diffuser sheets in back to front. They are sorta one-way devices unless the light is exactly on axis....
      TELEFIX
      • Jonny g
        • Jan 2016
        • 13
        Re: LG 47ln549c
        What i thought but they only fit one way, just uploading some pictures. There are 4 sheets in total. One thick, followed by a shiny mirrored/silver and 2 thin white sheets.
        • Alastair E
          Chief Womble
          • Mar 2013
          • 1963
          • U.K.
          Re: LG 47ln549c
          As I said--Inside out, ie--Backside is now on the front....
          They Will Fit Inside out, Done it myself....
          They need to be in the correct order too....
          Silvered sort nearest the thick plastic sheet, then the white ones...
          TELEFIX
          • Jonny g
            • Jan 2016
            • 13
            Re: LG 47ln549c
            So they do fit another way round?
            Silver first and then the other two on top, these seem exactly the same but can only get them one way to line up with the slots on edge.
            • Jonny g
              • Jan 2016
              • 13
              Re: LG 47ln549c
              Could it be that the diffusers have failed? As iv seemed to try every way round but light still seems to seep through :/
              Can you buy new ones if so other wise anything else you suggest trying?
              • Jonny g
                • Jan 2016
                • 13
                Re: LG 47ln549c
                What did you mean by the light being exactly on axis....?
                • RobbieC
                  • Sep 2013
                  • 26
                  Re: LG 47ln549c
                  They wont fit the wrong way round as the cutouts on the edge will be out but they will fit out of sequence if you mixed them up.
                  It took me a while to work out the correct way too!
                  • Jonny g
                    • Jan 2016
                    • 13
                    Re: LG 47ln549c
                    It's driving me mad ���� when I put then on every way I still see small circles of light. Will there always be? Just weather it shines through the screen?
                    • flocko
                      • Nov 2012
                      • 1121
                      Re: LG 47ln549c
                      Have you put the white plastic cover (reflector with holes in) and spacer clips back over the LED strips?
                      • Jonny g
                        • Jan 2016
                        • 13
                        Re: LG 47ln549c
                        Yes Iv done that but think Iv just made the problem worse. Caught one of the ribbons and bulled it off the board and now there's lines down the screen. Is this fixable or not now?
                        • Jonny g
                          • Jan 2016
                          • 13
                          Re: LG 47ln549c
                          http://m.ebay.co.uk/itm/Lg-47ln5400-...ATCHING_ACTIVE
                          I pulled one of the ribbons off this board.
                          • Jonny g
                            • Jan 2016
                            • 13
                            Re: LG 47ln549c
                            http://s1175.photobucket.com/user/Jonny-G/library/
                            • flocko
                              • Nov 2012
                              • 1121
                              Re: LG 47ln549c
                              There is no way of repairing the detached ribbon sorry
                              • Jonny g
                                • Jan 2016
                                • 13
                                Re: LG 47ln549c
                                Iv been told there is as they are sold on eBay a lot. Asked the seller and he said its best to ask a repair person as they are buying them from him.
                                • howardc64
                                  by howardc64
                                  Problem
                                  08-04-2024, 10:36 PM
                                  Lithonia Lighting versus Light of America Compact Fluorescent product quality
                                  by sam_sam_sam
                                  I have a Lithonia Lighting 65-Watt Gray Hardwired Compact Fluorescent
                                  I also have back when Light of America had these light bulbs available for yard lights
                                  The issue with Light of America was the blast boards had all most certain board failure while bulbs hardly ever fail
                                  While the Lithonia lighting fixture has all most certain bulb failure
                                  So I have modified the Lithonia lighting fixture to accept the Light of America light bulb and see how long this will last
                                  I have only had this light fixture for not more than a year if it...
                                  07-02-2023, 03:45 PM
                                • Pipolups
                                  Corsair K70 LUX RGB dying LEDs
                                  by Pipolups
                                  Hi there !
                                  I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
                                  Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
                                  10-08-2024, 11:58 AM
                                  LG Gram Ultra-light Weight Notebook Specification for Upgrade or Repair
                                  This specification for the LG Gram Ultra-light Weight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-light Weight boardview and Ultra-light Weight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                  09-07-2024, 03:40 AM
                                  LG Gram Ultra-Light Laptop Notebook Specification for Upgrade or Repair
                                  This specification for the LG Gram Ultra-Light Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-Light Laptop boardview and Ultra-Light Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                  09-06-2024, 09:10 PM
