LG 47LD450 - Will work for a couple days, then dead set
  • bmschiizz
    • Oct 2015
    • 22
    Hey guys, This is a great community that has already helped me through some TV repairs. For that I thank you. Hopefully you can assist me with this one because I am very stumped and cant find any info on this issue.
    This TV will work perfect for a few days. Then you will go to power it up and there will be no power and no standby light. Measuring the standby pins at the power supply in this condition give a reading of 0V. Actually all pins going to the main board are 0V in this state.
    Unplugging the unit for a while will usually solve the issue for a few more days. This would point directly to capacitor issues would it not? I've checked most of the capacitors on the secondary side of the PS out of circuit and will continue checking them tonight.
    Am I on the right page here? I would like to repair this board on a component level as the Canadian Dollar exchange rate is horrendous at the moment and all boards i can find are priced in USD.
    I did post on the welcome page but it looks like I'm still blocked from posting attachments as indicated my the box in the bottom left.
    I have pictures I will post as soon as I see that I am able to
    • 31026
    Re: LG 47LD450 - Will work for a couple days, then dead set
    small caps on the primary side or cracked soldering are main suspects.
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      there is a issue with attaching pictures at the minute due to the server swop you can use imgur to upload the pictures for now.
      • freakaftr8
        • Oct 2012
        • 3743
        Check for burnt solder or dry joints within the power supply inductors.
        • bmschiizz
          • Oct 2015
          • 22
          By small caps do you mean the extremely small ones by the ICs?
          Would this close up be burnt joints? they are on 2 components labeled P605 to P608.
          I'm not sure what they are. they are the two black coin shaped components above the inductors
          • freakaftr8
            • Oct 2012
            • 3743
            They look good. When you have no standby what are you measuring on the two main filter capacitors next to the two yellow transformers? You should have about 170 volts DC there. Be careful as this section is always hot
            • bmschiizz
              • Oct 2015
              • 22
              To my surprise when I reinstalled the board into the TV and plugged it in the TV went directly to the no standby light condition. This is the first time it has been dead after being unplugged for a while. And it had been a while as I removed and re-soldered a few caps for testing over the last few days.
              So the voltage across the main caps is 161V
              The voltages on the P201 connector to the main board are
              Power on 0V
              20V - 0V
              3.5V - 3.4V* thought I measured these as 0V before.
              12V - 0V
              error - 0V
              a.dim - 0V
              p.dim - 0V
              Its been plugged in at least half an hour with no heat coming from anywhere on the power supply board
              • howardc64
                by howardc64
                Problem
                08-04-2024, 10:36 PM
              • araxnido
                Programming KBC IT8987VG ASUS TUF FX506L RT809F+PEB
                by araxnido
                Dear friends, I want to share my experience repairing an ASUS TUF FX506L gaming laptop motherboard: DABKXDMB8E0_F_BKXD. Boardview and schematic are available, as well as the BIOS and ITE ROM.
                When the customer brought in this laptop, it was initially dead; it showed no signs of booting for any reason. After hours of measurements, checking each stage, MOSFET, and seeing if there was a short circuit in any capacitor, I discovered a strange 0.7V leakage voltage on the 3V_S5 rail, particularly on the PL9 coil, with the board not powered on. There were 3V_LDO and 5V_LDO voltages, which...
                06-10-2025, 09:26 PM
              • C152Heavy
                Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
                by C152Heavy
                Summary for TL-DR readers:
                • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
                • Have obtained Samsung schematic & service documents - Can upload if helpful.
                • Have read ALL applicable threads
                • C1818 and CP820 replaced as low hanging fruit
                • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
                • VCC pin (18) of PFC...
                01-11-2023, 02:53 PM
              • fiveseventy
                RX570 dies completely, then recovers.
                by fiveseventy
                Hello all,
                I have a Sapphire Radeon RX 570 Pulse ITX 4GB (single fan) which has started misbehaving recently.
                The card was bought used maybe 5 years ago and has worked without issue until recently.
                I have no reason to believe it has been worked on or physically damaged.
                For periods of time it will be 100% perfect.
                Perfect temperatures, no glitches or artefacts, solid FPS.
                I can game, run benchmarks, do whatever without any problem.
                I can reboot the machine as many times as I like and nothing changes
                however, most times...
                06-22-2024, 05:29 AM
              • VikramB
                Samsung QN55LS03 | The Frame TV | Weird power cycle and restart problem
                by VikramB
                First thread here on this forum, excuse me if I miss something in my first post.
                I have the 55” variant of the Frame TV which is essentially a QLED tv. There's a weird problem where it would keep on restarting on its own. Funny thing is it might work perfectly for couple of days and then decides to go down the restart route. A few pointers:
                1. If I let the TV sit idle for a day, for the very first time it boots after that time period it usually keeps working for 5 minutes before restarting. After that it restarts every 5 seconds.
                2. I've tried the tape method and...
                03-17-2023, 02:56 PM
