Quadro tft 37kl25 hd
  • nbdy
    • Aug 2015
    • 162
    • Croatia
    Hi
    Got the vestel 17pw20 v2 power source ...
    The 24V is on for 3-5 sec,then drops to 0.6V
    The blue (on) should be 5V but is 0.44V
    Any one knows what to check
    The 15nF/4700uF/220uF/1uF/4,7uF capacitors changed, the resistors 6193 are all ok
    thx
  • nbdy
    • Aug 2015
    • 162
    • Croatia
    Re: Quadro tft 37kl25 hd
    Another problem, the tv stays on for 10-15 minutes then shuts down, is the motherboard faulty or somthing else
    I have all the voltages from the power supply
    Thx
    • Agent24
      I see dead caps
      • Oct 2007
      • 4973
      • New Zealand
      Photos?
      -David VanHorn
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Poll cap failure is my bet, upload some images please.
        • nbdy
          • Aug 2015
          • 162
          • Croatia
          Sorry was on a field bussines,here are the pics:
          the main board
          https://www.dropbox.com/s/2mbm9u6kpf...71719.jpg?dl=0
          the power supply board
          https://www.dropbox.com/s/19vof47of1...71724.jpg?dl=0
          working just fine,and
          https://www.dropbox.com/s/b92slkmtcz...71933.jpg?dl=0
          goes to standby mode
          https://www.dropbox.com/s/rwyka7p7on...73018.jpg?dl=0
          this is my first upload to cloud,say if you don't see the pics
          the tv works for about 5-10 min and goes to stand by
          after 3-4 times turnning it on it goes immediately in stand by
          thx
          • Electronic Handyman
            • Apr 2016
            • 58
            This is just my opinion and it could be a faulty regulator etc but I'am wondering if you've gone over the power supply board and checked the soldering connections bec it sure sounds like either a bad cap or a bad connection or a combo of both.The caps that you replaced did you use Low ESR good quality caps? Dis you check the other parts that are connected to any known bad caps that you have changed? Did you change all the caps close to the heatsinks? When you double check the board be sure to look at all the hot spots very closely.When the set kicks off if you let the set sit unplugged for awhile does it start up and perhaps work longer?Again from what you're mentioning it could be a cap that is not holding it's charge properly or a solder connection that is disconnecting itself after it gets hot etc.Don't forget to check the regulator connections too.
            • nbdy
              • Aug 2015
              • 162
              • Croatia
              when i turn it off (power button) and back on,the tv works for 5-10 min again
              the caps changed are the best i could get in croatia
              didn't change all the caps near the heatsinks
              checked the solder connections,they all where ok
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Checked the Polly caps above the transformer ?
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  I had a similar faulty power supply and it was one of the smaller electroytic capacitors but I cannot remember which one. Check the ones that I have highlighted. It had gone high ESR approximately 17 ohms.
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    You need to check the Poly caps at the top of the Psu as imaged, they can cause this issue:
                    • nbdy
                      • Aug 2015
                      • 162
                      • Croatia
                      think it are the poly caps,but till monday nothing,gota buy them
                      thx for now
                      write back when i change the capacitors
                      • nbdy
                        • Aug 2015
                        • 162
                        • Croatia
                        Changed both electrolytic and the poly ...
                        the tv works for 50-60 minutes and goes to stanby...
                        when i try to turn it back on it goes to stanby at once
                        • Kilroys
                          • Feb 2014
                          • 70
                          • Sweden
                          Had a PW20 that went to standby after about an hour.
                          It was ic807 which was temperature sensitive.
                          • dick_barton
                            • Aug 2015
                            • 6643
                            • Wales
                            So you have an improvement on the original 10 - 15 mins. Have you tried using freezer spray on the power supply components to see if you can bring it back out of standby.
                            • nbdy
                              • Aug 2015
                              • 162
                              • Croatia
                              Sorry I have a lot of work outside my home ...
                              IC807, have to look ...
                              I dodn't try to use a freezer spray,but after a minute if you turn it on,it works for another 30-more minutes
                              • nbdy
                                • Aug 2015
                                • 162
                                • Croatia
                                Changed the IC807, all right now ...
                                TV works
                                thx all for help
                                  Thanks for the follow-up, so what is the P/N of this IC807? It will be good to know what the function of that IC is and what DCV we get when it is not working.
                                  • dick_barton
                                    • Aug 2015
                                    • 6643
                                    • Wales
                                    IC807 looks like it's a KA3525A which is an SMPS CONTROLLER, 16-DIP
                                    http://uk.farnell.com/fairchild-semi...|match|p|plid|
                                    • nbdy
                                      • Aug 2015
                                      • 162
                                      • Croatia
                                      Sorry for late reply,I work off my home ...
                                      Yes like dick wrote the P/N of IC807 is KA3525A
                                      greetz
                                        HP Z440 + Quadro K620 2GB i7-6700 Specification for Upgrade or Repair
                                        This specification for the HP Z440 + Quadro K620 2GB can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Z440 + Quadro K620 2GB boardview and Z440 + Quadro K620 2GB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                        09-12-2024, 03:30 PM
                                        HP 240 MT + NVIDIA Quadro K620 i7-6700 Specification for Upgrade or Repair
                                        This specification for the HP 240 MT + NVIDIA Quadro K620 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the 240 MT + NVIDIA Quadro K620 boardview and 240 MT + NVIDIA Quadro K620 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                        HP 230 MT + NVIDIA Quadro K2000 + Z24i E3-1226V3 Specification for Upgrade or Repair
                                        This specification for the HP 230 MT + NVIDIA Quadro K2000 + Z24i can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the 230 MT + NVIDIA Quadro K2000 + Z24i boardview and 230 MT + NVIDIA Quadro K2000 + Z24i schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                        09-12-2024, 03:28 PM
                                        HP 440 MT + NVIDIA Quadro K2200 + Z27n E5-1620V3 Specification for Upgrade or Repair
                                        This specification for the HP 440 MT + NVIDIA Quadro K2200 + Z27n can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the 440 MT + NVIDIA Quadro K2200 + Z27n boardview and 440 MT + NVIDIA Quadro K2200 + Z27n schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                        HP 440 MT + NVIDIA Quadro K2200 + Z24s E5-1620V3 Specification for Upgrade or Repair
                                        This specification for the HP 440 MT + NVIDIA Quadro K2200 + Z24s can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the 440 MT + NVIDIA Quadro K2200 + Z24s boardview and 440 MT + NVIDIA Quadro K2200 + Z24s schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
