Panasonic TCP50VT25 Audio
  • ljintexas
    LJinTexas
    • Jan 2015
    • 669
    Set has been working flawlessly since repair of su/sd/sc boards. When trying to play an MP4 movie, got the message "on screen audio not compatible". I have no audio period since that message displayed.
    Video is clear as a bell channels change quickly..just no audio.
    Unplugged from AC power for 15 min...still no audio.
    Any ideas??
    TIA
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Re: Panasonic TCP50VT25 Audio
    Unplugged the mp4 source? Remove all equipment like amplifier/soundbar etc so you just have the tv only.
    Tried to restore to factory settings?
    • tw2005
      • Oct 2011
      • 6458
      weird, I wonder if there is an option in your setup r if it's disabled somehing? May have to try a reset and see what happens.
      • ljintexas
        LJinTexas
        • Jan 2015
        • 669
        According to the tech serv manual..even if speakers go bad or wire pinched..should go off on a protection fault. The fact that I have video means all hardware checks out. going to power down for an hour then try factory reset.
        • ljintexas
          LJinTexas
          • Jan 2015
          • 669
          This is weird..In Advanced Audio settings, input for HDMI1 was changed to Component instead of Digital..changed back to Digital and sound returns. CPU must have changed it...tried it again on same file...changed again. Wow!
          • tw2005
            • Oct 2011
            • 6458
            was interesting. I was thinking along the line of it changing something although never come across this before. Glad it's sorted , sure to help someone down the track
            • ljintexas
              LJinTexas
              • Jan 2015
              • 669
              Well, according to all I found in tech serv manual, if it has video, it's not hardware..bad speaker, pinched wire, or bad IC will trigger protection fault with blink code.
              • samson7point1@yahoo.com
                Help troubleshooting an audio problem with an RCA SGT-250 CED Player
                by samson7point1@yahoo.com
                The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
                The player processes the audio signal using two different reference frequencies. The "R"...
                04-30-2024, 11:22 AM
              • ItepK
                Panasonic TX-P42G30E green light blinking, no video, no audio
                by ItepK
                Hey everyone!
                I've gotten this TV for free, neither have it seen a TV repair man, neither have it been opened before.
                This post describes my entire troubleshooting process of this TV.
                When I turn it on using the ON/OFF switch at the side of the TV, the light rapidly flashes green, then it stays on, but it does not react to any of the remote buttons, side buttons, and doesn't play audio.
                I've taken the unit apart, and I've started to check some voltages:
                • On the P11 connector, there is 15V DC only for a brief moment, then it goes
                12-22-2023, 05:06 AM
              • i_am_patch
                Roland KR-3500/4500 Digital Piano. Crackling audio sound on all keys -Fixed
                by i_am_patch
                Hi All. I had a Roland KR-3500 Digital Piano (similar to the KR-4500) that exhibited a Crackling audio sound on all keys. After reading somewhere about someone with a similar issue who had replaced all the Electrolytic caps I decided to also go down that route. (Spoiler : It worked !) After some basic troubleshooting I determined that it could be noise feeding thru from the Keyboard scanning since the Demo tunes played back undistorted and the Audio amp / speakers were fine ( Inserted an Audio signal into the rear Audio input). After extracting the main board from the shield, I replaced 7 Capacitors...
                04-30-2024, 08:20 PM
              • Andre Gilbert
                by Andre Gilbert
                11-20-2024, 08:52 PM
              • silver60618
                Macbook M3 A2991 Speaker Audio Amplifier IC
                by silver60618
                Im working on a 2023 Macbook Pro M3 A2991, that had a liquid spill, has no sound. Corrosion found near Speaker Audio Amp IC. Chip ID SN012776B0,
                I did find a SN012776B0 on A2442 model, but the sub and replaced it, no go. Anyone know if these audio amp IC's are cross compatible between 2021-2023 models?...
                09-26-2025, 12:25 PM
