4K Vizio P702ui-P3 No Picture, No power to T-Con
  • archer*99
    • Feb 2020
    Re: 4K Vizio P702ui-P3 No Picture, No power to T-Con
    Hello no 12 v to t-con defective main pwb.. if all other voltage good. common on set with years hours use the main micro develops cold solders due to heat as surface mount, note the size of heat sink verse chip . if the ground pins float the chip fails .
    • Fly_Among_Stars
      VIZIO E70-E3 Half picture with half TCON
      by Fly_Among_Stars
      I have a VIZIO E70-E3.
      Symptoms: Black screen, no picture, but LED backlights are working.
      I probed the power board and voltages are as listed on the board.
      Main board appears fine, too.
      I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
      There are two separate ribbon cables feeding the LCD.
      If both are connected, the screen is black.
      If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
      04-24-2023, 08:20 PM
    • iglitare
      Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
      by iglitare
      i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
      Backlight seems to work, Sound (Setup menu after reset) works.
      If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
      Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
      With my small knowledge i would think at least the cables are good.
      Can this happen because of a bad tcon board?
      Or is it always a bad/shorted...
      09-04-2025, 07:13 AM
    • Awsmessymail
      Vizio E701i-A3 backlight only and now no backlight
      by Awsmessymail
      Hello all,
      I’ve tried to repair TVs in the past with some luck. Toms repair manuals got taken down and now thats a bit harder.
      I picked this TV up hoping for a quick fix. When the TV would power on, only the backlights would come on. The owner told me they heard loud screeching before it shut off. This alone makes me want to think the main board has an issue.
      As I researched, I found the TCON/driver boards were an issue on this unit. I went in troubleshooting the TCON but found good voltages on the TCON. I followed shop jimmys guide to test the transistors and they seem okay....
      02-13-2024, 11:04 PM
    • ggil44
      Vizio M65-E0 No Picture, No Sound
      by ggil44
      Hi I inherited a Vizio M65-E0 that isn't working. It must have been dropped on the corner because I found that the infrared circuit had a capacitor with one end broken off of the board and some green corrosion around the plug to the main board. I re-soldered the capacitor and cleaned the corrosion well and tried turning the M65-E0 on and I was successful. My problem is that while the back lights come on and appear to perform local dimming there is no picture or sound. It kind of looks like you are looking at the TV through a very dense fog, where changing the input on the remote will change bright...
      09-03-2024, 08:30 PM
    • maricm
      Vizio m65-c1 picture flashing on and off on the screen
      by maricm
      HI all,
      hope someone point to the possible issue before I start buying replacement parts.
      Tv starts normal and responds to remote fine, PSU voltages mesured fine 19v was 18.9V under load and 19V with main board disconnected.
      Backlight stays on all the time,
      Sound works fine.
      screen keeps changing form black to full picture in about 1sec intervals.
      Picture looks fine with no visible artifacts.
      I have disconnected backlights and flashlight test confirmed that picture is still doing the same.
      Disconnecting left and right ribbons on...
      11-25-2023, 06:32 PM
