Anyone know where to find firmware Teac DLE5089FHD?
  • jwarnes
    • Feb 2014
    • 29
    Looking for where to find firmware for DLE5089FHD teac 50inch tv.
    Stuck in red led standby. Power supply ok.
    Heard somewhere its usually a firmware issue and that i need to put the firmware update file in a usb stick and turn it on and let it update?
    Mainboard number is TTMSD306.69A
    any help GREATLY appreciated.
  • jwarnes
    • Feb 2014
    • 29
    Re: Anyone know where to find firmware Teac DLE5089FHD?
    No one had any experience with this problem before??
    • slavetothesound
      HP ProDesk 600 G6 Mini BIOS unlocked - now EC can't find valid firmware
      by slavetothesound
      I Used a T48 and RCUnlocker to remove password from the BIOS on a previously fully functional HP ProDesk 600 G6 Mini. Everything went very smoothly and I was able to boot the machine and install an OS. I then unplugged the machine and put it on the shelf for a week.
      Now when I boot the machine, it does not POST. It plays 5.2 beep codes which are interpreted as:
      I read the firmware with the T48 and it is different than what I flashed to it, so I flashed the unlocked firmware that I had saved. No change. I could use some advice on next steps to take.
      04-12-2024, 10:05 AM
    • Coldblackice
      GoXLR-Mini.Possible to extract this firmware? Or find its datasheet?
      by Coldblackice
      I'm trying to extract firmware from a GoXLR-Mini
      https://www.tc-helicon.com/product.html?modelCode=P0DI7
      I know it's not ideal, but I'm trying to extract the 64MB firmware without removing the chip. I've done this before, but I realize it's a case-by-case thing. Unfortunately, it seems this board's layout results in it getting powered by my SPI tool (Buspirate), failing extraction.
      I believe the issue is the flash chip's HOLD pin unable to get pulled high, as the current for that pin dissipates elsewhere in the circuit. When I try to pull the HOLD pin...
      02-25-2022, 06:27 AM
    • gurj1979
      Ubiquiti firmware help. US-8-150W POE
      by gurj1979
      Hi guys.
      I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
      Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
      So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
      Got New chip and writes good.
      THE PROBLEM...
      It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
      Does anyone have a Good Firmware I can have?...
      07-22-2024, 05:13 PM
      by Vesko356
      08-11-2023, 03:27 AM
    • Daniel Larsson
      Firmware file for LG SK10Y Soundbar stuck in Please wait loop needed
      by Daniel Larsson
      My LG Soundbar, SK10Y, has somehow ended up in an endless "PLEASE WAIT" loop and I am now starting to suspect that the firmware is causing this, and I can't manage to connect via the app to push a new firmware in as it never really starts.
      I can trick it to start via HDMI ARC and it actually starts up, flashes OPTICAL and then goes to ARC where the sound (including sub) is perfect, but the white led indicator keeps blinking and after 20 seconds it says "GOOD BYE" and shuts down.
      During these seconds the function button is not working...
      08-13-2025, 10:29 AM
