BN96-09744A Samsung TV Module, Y-Main board, LJ41-06153A, PN58B550T2FXZA
  • R1racer
    • Nov 2015
    • 66
    Does any one know the way to test and determine which component is bad on this Board . I already replaced it and got my TV set working but would like to repair this one
    [/URL][/IMG]
  • chico1st
    • Jan 2012
    • 21
    Re: BN96-09744A Samsung TV Module, Y-Main board, LJ41-06153A, PN58B550T2FXZA
    the jist of it is to look for components which dont work somewhat like they should.
    nothing should have 0 ohms to ground (the trace where the screws attach). Probe around and see if you can something that does. Most likely it will be one of those components with a heatsink that shorts to ground.
    then you have to look to see whats broken in that area that goes to ground. then it gets harder especially if you dont know electronics and it feels like you are just looking at random objects. going from finding the bad part to fixing it isnt trivial but doable.
    • R1racer
      • Nov 2015
      • 66
      ^^ This board is a spare and don't mind to spend some time chasing the bad component, However nothing out of the ordinary ( blown , burn, cracked ) In fact the voltage at the test point AKA VSCAN with dead on but once i replaced the board baam i have 100% functional set.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        So have you checked for S/C ?
        • R1racer
          • Nov 2015
          • 66
          Am assuming you asking if i checked for short circuit ( Which circuit specifically)
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
          • ohren
            Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
            by ohren
            I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
            I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
            The models launched in 2018 and 2019 respectively....
            09-08-2023, 05:24 PM
          • C152Heavy
            Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
            by C152Heavy
            Summary for TL-DR readers:
            • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
            • Have obtained Samsung schematic & service documents - Can upload if helpful.
            • Have read ALL applicable threads
            • C1818 and CP820 replaced as low hanging fruit
            • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
            • VCC pin (18) of PFC...
            01-11-2023, 02:53 PM
            09-07-2024, 05:50 AM
