Sharp TV LC-32LE600E randomly shuts off
  • atanas_ko
    • Dec 2015
    Some time TV shuts down with shut like cannon from the speakers. This happens in TV mode and VGA mode. After that I dont turn it on.
    All power supplies are OK. I measured all caps. They are OK.
    Any advices?
  • sordids999
    • May 2013
    • 2161
    • uk
    Re: Sharp TV LC-32LE600E randomly shuts off
    Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
    • dmcabs
      SHARP LC-60LE640X display flashing white noise patches and totally dropping out randomly
      by dmcabs
      Hey guys,
      I have a SHARP LC-60LE640X TV that has suddenly developed an intermittent fault of flashing white noise patches (appears like an Analog tuner off signal) and then totally dropping out.
      This model I believe is also known as LC-60LE600U or LC-60LE640U in other regions.
      FYI, a long time ago I was a component level repair tech for all consumer electronics and IT equipment.
      I'm a bit rusty but still have ability to dig right down.
      I measured all power supply lines and checked them for AC ripple voltage. Noting any lines that exceeded about...
      09-21-2024, 11:09 AM
    • Michale32086
      FUNAI/SANYO FW55D25F Shuts Down Randomly
      by Michale32086
      I have Sanyo 55" TV that randomly shuts off..
      Sometimes it will stay on for 5mins or so, sometimes it shuts off after a min or two...
      When it DOES stay on, it works fine...
      All things being equal, would it be more likely a POWER Board issue or a MAIN Board issue???
      Thanx in advance......
      07-12-2022, 12:41 PM
    • Soldiaz
      SAMSUNG LE37B650 T2PXZG shuts off randomly after wait possible to turn on again
      by Soldiaz
      Dear folks I am facing this issue and hope anyone can assist.
      TV shuts off in use, Black screen,no sound, no Power LED.
      After unplug and wait Power LED lights up again and I can use it until it shuts off again, showing no LED, no Sound Black screen.
      I attached psu Board pic hoping someone can assist, thanks in advance.
      P.s. 1st thought Was about the powerboard since no power led......
      07-24-2022, 06:06 AM
    • 90Ninety
      Crappy Vestel/Sharp LC-40FG3141K Set Backlight going off randomly
      by 90Ninety
      Hello
      Model Code Sharp LC-40FG3141K
      Firstly perhaps I should save myself the agony and throw this set out ? Then again I hate E-waste , or giving a person further headace in the far east or Agbogbloshie . So I digress to my last hope of fixing this pile of shite , with the dash of hope from your combined experiences
      So this set is randomly turning off its backlight ( could be days, hours, minutes or seconds ) , my research suggests this maybe an over current protection , or leaky/faulty LEDS , or a bad LED driver circuit . So I opened it up , stabbed my Multi...
      07-06-2022, 07:09 AM
    • gavenb
      Sharp LC-80LE661U 80 inch
      by gavenb
      Hi folks!
      I have a LC-80LE661U that had some interesting issues.
      Initially, it would come on and show the sharp logo and would show normal static before shutting off.
      I started troubleshooting by disconnecting the led lighting strips and turning it on. It would do the same thing - come on, show the sharp logo and shut off. After reading, it was suggested to replace the main board. That was replaced and the same symptoms resulted. After this and some reading, the parts cannon got loaded up. I replaced the power board, same issue. Replaced the Tcon board and now it...
      11-12-2023, 02:05 PM
