LCD Samsung LE40B651 start loop
  • cristi16707
    • Dec 2015
    • 6
    • Romania
    I have an issue with my Samsung LE40B651 LCD, and I need your help.
    Few weeks ago, when I tryed to power on from stdy,I got it in totaly blank status: no stdy LED, no sound, no backlight. Thanks to your help indication (especialy budm and tom66) I was able to fix power supply board (BN44-00264A) by replacing of UM801S(STRW6252).
    Now I have 5.3V, 13V on CNM802, CP815~390VDC,I get stdby LED, I can power on from sdtby, I get starting sound, I get backlight, but not any image. After around 5 seconds it reboot again, and again .. and so on. For more details about simptoms, please follow below video :
    https://www.youtube.com/watch?v=ufYw...ature=youtu.be
    If I pull out connector between power supply and main board, I get a stable backlight status.
    If I pull out connector between main board and Tcon, the start-up loop is still there.
    Could you give me some advices, please ? Can be a main board issue (BN40-00145A) ?
    Re: LCD Samsung LE40B651 start loop
    It does sound like you have main board problem since you are getting the backlights when the cable between the main board and the power supply board is disconnected.
    BTW, what happen if you disconnect the cable between the remote IR and the key panel button board?
    Try heating the main board with hair dryer for a few minutes to see if the symptom changes.
    • cristi16707
      • Dec 2015
      • 6
      • Romania
      I suppose you referred to cable from attached picture. When I disconnected, nothing happen, as the TV is in stdby, but cannot power on it.
      I tried to heat the mainboard for a few minutes but not any change.
      New idea ?
        New idea ?
        Forget to tell you to turn the TV on first then disconnect the cable, if it still does the same thing and heating the board does not make the difference, then just need to get the new working main board.
        • cristi16707
          • Dec 2015
          • 6
          • Romania
          I disconnected IR cable, after power on, but still the same result.
          Then I "cooked" the board but with not any result. I tried again to disconnect IR, but the same. It seems that I have bad lucky !
          Are you sure that main board is issued ? Do you know some equivalent boards for BN40-00145A ?
          • johnboy1313
            • Nov 2012
            • 1959
            BN40-0145A is the tuner part number. The main board should start with BN94. It looks like your board is actually BN94-02583U.
            • cristi16707
              • Dec 2015
              • 6
              • Romania
              Yes, you are right. I attached tuner picture.
              As not any new idea, I'm looking for such kind of board. I keep you post about result.
              Thank you for your support !
              • cristi16707
                • Dec 2015
                • 6
                • Romania
                After main board replacement TV works fine.
                Many thanks to budm !
                  Thanks for the follow-up on the repair.
                  • Asraf Atb
                    by Asraf Atb
                    01-27-2025, 05:02 PM
                  • Dani_2024
                    by Dani_2024
                    10-28-2024, 05:06 PM
                  • ygorsan
                    by ygorsan
                    🧩 Problem Summary:
                    • I
                    07-28-2025, 08:34 AM
                  • Lee M.
                    Samsung UN75RU8000FXZA bad main board?
                    by Lee M.
                    When plugged in it will click and cycle the BL on and off, no pic and does not respond to remote. When I disconnect the cable from the PS board to the main board and then plug it in the BL will come on and stay on. There are only two boards in this set, the LVDS cables from the panel driver boards connect directly to the main board. Since the BL comes on and stays on I'm thinking the PS board is ok and the problem is on the main board. Should I order another main board or do I need to do more testing? thanks, Lee
                    11-08-2023, 07:46 PM
                  • jb_Bak
                    by jb_Bak
                    CN6401
                    Pin 01 NC
                    Pin 02 NC
                    Pin 03 "BL_ON": 0V
                    Pin 04 "N/C"
                    Pin 05 "STBY 3.3V": 3.5V
                    Pin 06 "GND": N/C
                    Pin 07 "AC_OFF"...
                    09-27-2021, 04:52 PM
