I have a funai lf320fx4f s/n ds2a1337268930 (a3afnuh) and 2 of leds in the strip have burnt out, causing my tv to blink the logo then go off. (led strip Part# UDULED0GS015 REV.B and 32W16S1P) Both power and main boards have been replaced to no avail. the only place i can find that sells them is shopjimmy they have 2 types this one http://www.shopjimmy.com/funai-u34f4...ps-1-strip.htm which matches the part numbers on mine but is out of stock they also have this one http://www.shopjimmy.com/emerson-fun...ps-1-strip.htm that looks exactly the same and is in stock. Do you think this will work? Is there anywhere else to buy this it? Thanks in advance
led strip for funai lf320fx4f
Re: led strip for funai lf320fx4f
If you look at SJ, you can see what LCD panel they are made for, so what is your LCD panel model number?
BTW, how many strips are there inside the panel, it does look the same but one is made by SAMSUNG ($19), and the one is made by LG iNNOTEK.Last edited by budm; 12-14-2015, 06:12 PM.Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809 -
For: Panel Sticker Number: U34F4XT / U34F7XH
BTW, after you are done, make sure to turn down the Backlights level as low as you can to extend the life of the LEDs.Last edited by budm; 12-14-2015, 06:17 PM.Never stop learning
Per shopjimmy, it is made for your panel, U34F7XH.Never stop learning
You can also verify with SJ when you place an order.Never stop learning
by edugimenoHi There!
I'm trying to help my friend who owns a restaurant be just bought.
He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
It's stuck using, I guess, the 2 sided tape that comes with the strip
The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth... -
by DynaxSCHi,
Usually on ASUS boards it worked...-
by adelageHi, I am installing a long led strip and I noticed that it frequently flickers slightly, it is not a strong nor regular thing, but it is noticeable and annoying. I have measured the voltage of the mains and it shows some fluctuations, it normally stays at around 226v, but often (every few seconds) drops down to 218/219v), and the flickering happens exactly at the same time. I have measured this at the counter and with every appliance off, so it's not related to the house electrical system, but that's how it comes from the supplier.
I know that the best solution would be to get a voltage... -
Found an Funai 32FL553P/10 TV on sale for cheap listed as broken, so I decided to give a shot at reparing this.
State I got it in:
Squealing from the PSU
After logo I get a blank screen
After 10 seconds of having a blank display w/ backlight the TV dies
Give it 7-10ish seconds again and it starts to bootloop.
What I did so far:
Replaced all the caps on the PSU (apart from primaries, they were fine and none at hand)
Checked all voltage rails:
5VSB - 4.8V
AMP+13V - 14.4V
13V - 12.98V (in manual 12V)... -
by benareenoI wonder if i shorted the whole strip...where to put pos and neg to just light up a single diode...or the entire strip. The strip lit for a second...so maybe i fried it? What say you?
I have an adjustable dc power supply and was trying around 9 volts.
I have a pic of a single diode...where to put pos and neg terminals to light it up?
Pic of middle of strip..is this where i light the entire strip?
And pic of end...or does this light the entire strip?
Where to put pos and neg for single diode..multiple diodes and the entire... - Loading...
