Samsung no screen, audio works
  • sh1fx713
    • Dec 2015
    • The Netherlands
    Samsung Plasma modelnr: s42AX - YB04
    The screen on my samsung television stopped working but the audio still works. After reading information from this website i've openend the backpanel and searched for the problem. After checking the Va Vsc VS and Ve values i noticed that there was no Vsc value. So i checked the Y-Main board and there where some blown capacitators. I bought new cappacitators with the same specifactions and replaced them on the Y-Main. Unfortunately there is still no screen on the television. So i checked the Vsc again and the values on my multimeter is jumping all over the place.
    What i've done to find the problem:
    • -Ive checked the bufferboard for shorts, but the bufferboard seems okay,
    • -Meassured the powersupply on the testpoints
    • -Replaced Cappacitators on y-main board
    Ive also tried to meassure the Va value going to the y-main but im not getting any value, on other points im getting 205Volt. The power supply makes a click sound when turning on the television, and there is some buzzing sound from the coils on the power supply.
    Whats the next step to make my television work again?
    Any advice greatly appreciated.
    Pictures from the boards etc:
  • sh1fx713
    • Dec 2015
    • The Netherlands
    Re: Samsung no screen, audio works
    No advice from anyone?
    I really need some help.....
    • Chrissygizmo
      by Chrissygizmo
      02-10-2025, 12:33 AM
    • Chrissygizmo
      samsung galaxy ao2s very temperamental after screen replaced
      by Chrissygizmo
      Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
      Ive eventually managed to get it on and working but it's very temperamental...
      The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
      05-26-2024, 12:05 AM
    • JunkmanJimbo
      Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
      by JunkmanJimbo
      Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
      No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
      Please help. Thanks in advance!
      08-12-2025, 11:45 AM
    • Kiberge
      Samsung LH82QENELGC/EN Help needed - Static line on screen
      by Kiberge
      HI guys!
      I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
      I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
      the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
      This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
      04-22-2024, 11:28 AM
    • valvashon
      Samsung UN60JU6500, stripe on left side of screen
      by valvashon
      Friend sent me this picture of what their 60" Samsung from 2015 is doing. I didn't have any luck getting rid of a vertical stripe in another TV that developed one so I'm not too excited about trying to fix this one. It's mine for the asking; wish it had a dead power supply or bad backlights instead.
      Is this most likely to be a connection at the circuit board or where the ribbon cable hits the screen itself?
      Update: was just informed that this stripe comes and goes and has been doing this for a couple of months.
      Thanks, Val
      11-21-2025, 03:01 PM
