LG 60PZ950 - Horizontal purple lines
  • TMullenJr
    • Dec 2015
    Hello. I have found the articles in reference to the 550, and my internals are identical to the images in the other thread, so I believe my issue is the same cold solder joint issue.
    My question is in reference to the repair. When I attempted to use my 30 watt iron, it didn't affect the existing solder. Granted, it is an old iron, and may not be operating at normal temps.
    My question is what would be the appropriate heat needed to reflow the solder? I am always concerned that my 100 watt gun would generate too much heat and damage a component.
    Also, should I remove the old solder and apply new, or is reflowing the existing w/ a little new sufficient?
    Thanks for the advice.
    Tom
  • Hamie
    • Apr 2014
    • 1383
    Re: LG 60PZ950 - Horizontal purple lines
    Have you tinned your iron?
    A 30w soldering iron should be able to reflow joints.
    If your iron has become oxidised it won't work. (Ie: the tip should shine and when you touch it with fresh solder it should cover the tip, if it runs down the iron then it's not going to flow the joints.)
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
    • Ihandyrepair
      Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
      by Ihandyrepair
      Hi guys
      I just started fixing 4k TV few months ago. so I am still learning a lot
      I got this tv from friend complaint is ghosting or horizontal lines on image.
      never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
      then it started to show the ghosting white image.
      I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
      it has 3 thin small boards at the bottom of the...
      12-05-2022, 04:18 PM
    • ggil44
      Sony XBR-65X750D Horizontal lines bottom of screen
      by ggil44
      Hi, I have a Sony XBR-65X750D that has horizontal lines at the bottom 6 inches of the screen. These lines appear to be every other line because the picture is still quite visible behind those lines. The lines appear all the time with a few other lines above and below the 6 inch level blinking on and off at about 2 second intervals. I'm not sure if this is a panel issue or power supply/main board problem. I did replace the T-Con board without any change in the problem. Any suggestions you might have would be greatly appreciated. Thanks,
      05-30-2023, 07:51 PM
    • noisykid
      Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
      by noisykid
      5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
      12-30-2024, 07:15 PM
    • noipi
      samsung Oled 65 Horizontal Lines and Flicker
      by noipi
      I have samsung 65", i bought it last january 2025 2nd hand, and last month got this problem, flickering with horizontal lines. any inputs if this is Motherboard replacement or the LCD tcon, can someone help me what to do, i saw in YT, someone says that to cover the flex connector of the unit. Sorry for my english i am asian. i include the video so someone can help me out. thanks...
      10-14-2025, 02:11 AM
