Panasonic 8 blinks
  • tech2014
    • Aug 2014
    • 807
    Panasonic 8 blinks
    Does anyone know the part number for the 5.6 ohm resistor and the gate drive IC. I want to order these parts to have in my inventory. What is the footprint size of the resistor(0603??), and can i get it at digikey.
    thanks
  • tech2014
    • Aug 2014
    • 807
    Re: Panasonic 8 blinks
    Sorry I should have included a pic lol.
    This is on an TNPA5623AB SS board from a Panasonic TC-P50UT50.
    What size is it?
    • tech2014
      • Aug 2014
      • 807
      so nobody knows the size of this resistor?????
      • diif
        • Feb 2014
        • 6978
        • England
        Measure it. 0603 is 0.6x0.3mm and 1005 is 10x0.5mm
        • tw2005
          • Oct 2011
          • 6458
          0603 is imperial I believe so would be equivalent to 1.60 x 0.8mm
          • retiredcaps
            • Apr 2010
            • 9271
            @tech2014, it is not good form to ask the same question in more than place.
            https://www.badcaps.net/forum/showthread.php?t=50919
            --- begin sig file ---
            --- end sig file ---
            • diif
              • Feb 2014
              • 6978
              • England
              0402 and 0603 are Metric too, does anyone use imperial nowadays ?
              https://en.wikipedia.org/wiki/Surface-mount_technology
              • tw2005
                • Oct 2011
                • 6458
                Sure, but in the context of the original question it's imperial.
                Maybe not in electronics.
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  Thanks.
                  • Andre Gilbert
                    by Andre Gilbert
                    Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                    Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                    11-20-2024, 08:52 PM
                  • Biruslapio
                    Panasonic P58V11B 8 and 12 blinks error "fix"
                    by Biruslapio
                    Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                    Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                    04-13-2021, 07:13 AM
                  • jm1234
                    Panasonic plasma TX-P42ST50 - 6 blinks
                    by jm1234
                    anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                    It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                    I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                    I checked that board for any obvious faults...
                    05-22-2024, 06:59 AM
                  • jinu_j
                    by jinu_j
                    Hi
                    05-03-2025, 10:51 PM
                  • mikey5791
                    Need help to replace burned resistor in 350w atx psu
                    by mikey5791
                    Hi to all forum members,
                    Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                    The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                    Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                    Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                    12-26-2024, 04:55 AM
