LG Scarlet 47LG60
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: LG Scarlet 47LG60
    We need pictures of your tv and boards.
    • cheeky2
      • Dec 2012
      • 337
      Originally posted by Landslide
      Yes I have the 47LG60. The picture was from a screenshot of a youtube video. It may have been a different size model that was in the video but I figured it was similar enough. The video was in a different language so I couldn't understand it. When I look up T-Con boards, they all differ from the picture posted above by Casper250. This is what I see when looking for it...
      They differ as it's not the TCON board! The board is between the tcon board and the main board that is why you cannot find it! Get a service manual for it and you will see for yourself if it is the same model. These boards are rare to find as they regularly fail on the capacitors as the board gets hot. Get a competent person to replace them for you. I think there are around 15 of the 100uf capacitors to replace on the board.
      • howardc64
        by howardc64
        07-24-2025, 05:17 PM
      • Stanley1843
        by Stanley1843
        06-29-2024, 11:54 AM
      • jeyoung12
        Samsung QN50Q60t lines on screen
        by jeyoung12
        Hi all
        I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
        My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
        This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
        It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
        So....i don't know what end of the C ribbon to work with...
        02-26-2024, 10:38 AM
      • Rubenlily
        Samsung QE50Q67TAU - horizontal lines
        by Rubenlily
        First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
        I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
        I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
        I'm no expert but I've done the tape...
        08-16-2023, 01:12 PM
      • visionbluedemon
        Help. Sony kd-65x85dj vertical lines
        by visionbluedemon
        First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
        Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
        tried blocking LC lines too, but same results
        is it lcd panel issue or tcon board issue?...
        07-25-2025, 04:56 AM
