Firmware for LG 42LE4900
  • speedypro
    • Feb 2013
    • 561
    Is there an update for the LG 42LE4900? It uses netcast and I need netflix on it.
    Full-time computer repair tech (10am - 6pm) and full-time, (8am - 11pm), Ruby on Rails Developer
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: Firmware for LG 42LE4900
    Check with LG!
    TELEFIX
    • speedypro
      • Feb 2013
      • 561
      Originally posted by Alastair E
      Check with LG!
      That would be the first thing someone would do
      • Ltank
        • Jun 2013
        • 776
        Be careful on firmware updates, if you make a mistake your set may not function any longer. Search for post on this Site on how to do it.
        • speedypro
          • Feb 2013
          • 561
          Im aware of that. Thanks. Id just purchase a roku 2 box and use that instead.
          • TheUser
            Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
            by TheUser
            Hello to everyone ,
            This is my first post here, and i would like to share with you a small story in case you can help me.
            Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
            All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
            I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
            02-10-2024, 02:07 PM
          • rumpumpel1
            ThinkPad X12 Detachable Gen 1: keyboard after firmware update without function
            by rumpumpel1
            Lenovo System Update offered me an update for the firmware of the Folio keyboard for my X12 Detachable Gen 1. The update got stuck and after 20 minutes I switched off the laptop. Since then, the keyboard and touchpad have been without function. Does anyone know how I can revive it?
            10-24-2024, 08:59 AM
          • dkneyle
            Sony KDL-46HX850 Can't upgrade/update firmware
            by dkneyle
            Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
            Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
            09-25-2024, 10:44 PM
          • piernov
            Infineon TPM firmware update files
            by piernov
            Infineon TPM firmware update files:
            Infineon_firmware_update.zip
            Code:
            TPM12_4.32.879.0_to_TPM12_4.34.1010.2.BIN
            TPM12_4.33.949.0_to_TPM12_4.34.1010.2.BIN
            TPM12_4.40.119.0_to_TPM12_4.43.257.0.BIN
            TPM12_4.40.119.0_to_TPM12_4.43.258.0.BIN
            TPM12_4.40.119.0_to_TPM12_4.43.259.0.BIN
            TPM12_4.40.119.0_to_TPM20_5.62.3126.0.BIN
            TPM12_4.40.119.0_to_TPM20_5.63.3144.0.BIN
            TPM12_4.40.119.0_to_TPM20_5.63.3353.0.BIN
            TPM12_4.42.132.0_to_TPM12_4.43.257.0.BIN
            TPM12_4.42.132.0_to_TPM12_4.43.258.0.BIN
            TPM12_4.42.132.0_to_TPM12_4.43.259.0.BIN
            10-25-2025, 10:09 AM
          • pp74
            Marantz NR1508 USB firmware update image
            by pp74
            Does anyone happen to have the latest firmware for the NR1508? Marantz took their update server down and customer support refuses to provide the image to flash over USB.
            Regards
            05-10-2025, 11:55 PM
