Samsung plasma tv has vertical stripes
  • NTkiller7000
    • Dec 2015
    • 44
    Hi, I just got a 50" Samsung plasma TV for free, but it has a 2 1/2 wide band of color going down the screen. Model number PN50A450P1D. Since a pic is worth a thousand words, and a video worth a thousand pics here's a video for those who know about these TVs.
    https://youtu.be/8P3C2oyS-3M
    Any help would be appreciated! Thanks
    Last edited by NTkiller7000; 12-03-2015, 05:45 PM. Reason: forgot to add model number
    Just trying to make these stupid electrons behave!
    ...Not having too much success, they keep flying around those atom thingy-majiggers...
  • rccrasher65
    • Mar 2014
    • 626
    Re: Samsung plasma tv has vertical stripes
    That fault could be a tcon board issue, or a bad plasma panel.
    • NTkiller7000
      • Dec 2015
      • 44
      Well, I took the set apart and was looking around, and I think I might have found the problem. The video shows a vertical stripe going up the screen, right? well, I noticed the long thin boards at the bottom of the display, and the ribbon cables going from these boards to the glass. I placed the set on 2 pillows so I could work on it, and I turned it on wile it was face down. I then noticed the stripe was centered on one of the ribbon cables. These boards do not appear to be removable. To make things worse, I also noticed small ICs attached to the middle of the ribbon cables. If my educated guessing is correct, the TV is FUBAR, since I cannot replace the boards nor the ICs, unless I am missing something.
      • NTkiller7000
        • Dec 2015
        • 44
        I am probably going to part this TV out on eBay since it is not repairable. If there is a particular part any of you want, please reply.
          There is a fair chance this is a simple panel failure, however the repetitive nature of the fault makes me suspect something like a loose or damaged ribbon cable or a faulty t-con board.
          These TVs are very prone to panel failures, but you could be lucky and it might not be a panel fault.
          • NTkiller7000
            • Dec 2015
            • 44
            If it is the t-con board, is it possible to connect the cable for the right half of the pdp to the left t-con output? The cables appear to be identical, and the left side functions perfectly. I don't want to spend $40 dollars and find out that the pdp is what's broke. Side note: I unplugged the long board running across the bottom of the pdp, and the right side was covered in randomly appearing lines. I don't remember if the original lines were there or not, leaning toward not.Thanks!
            • NTkiller7000
              • Dec 2015
              • 44
              Ok, I got a chance to play around with it more, and it may be the t-con board. I unplugged the ribbon cable going from the t-con board to the board across the bottom of the screen, and the right side of the TV displayed faint static with no stripe... could that be indication of where the fault is? Also, I hooked everything back up and unhooked the LVDS cable (the one going from t-con to the motherboard, right?) and the TV displayed the stripe on a black background. What's weird is the stripe goes from color to a series of red lines every 1/8 inch or so after the TV has been on for a second.
              • kotel studios
                Samsung LC32HG70QQUXEN - vertical and horizontal stripes across the screen
                by kotel studios
                Just now my Samsung LC32HG70QQUXEN monitor gave up on me. On cold boots I get many vertical stripes going across the screen (see the attached picture). After it runs for 1-2 minutes those go away but there are horizontal stripes going across the whole screen no matter of the input and PCs I use. (couldn't take an picture of it since the image size goes to 20MB and the camera doesn't pick them up)
                In a video about a 27" monitor with an similar issue the guy removes one resistor and supposedly the entire monitor goes back to life? For sure this fix is only temporary....
                08-06-2025, 02:07 AM
                09-07-2024, 05:50 AM
              • Raulnn
                Samsung UE65SL003AU vertical stripes
                by Raulnn
                I have a TV with a Samsung picture frame that suddenly got vertical stripes. can anybody help me. Will it be tcon or panel? thank you
                11-26-2023, 01:36 PM
              • JesusJones
                Samsung Plasma Intermittent Vertical Bars (repeatable) PN50B430
                by JesusJones
                Trash picked this plasma for parts and found it had some bad solder joints. It powered on after reworking most of the boards and seems like it may even work.
                The symptoms is, when showing a picture of bright (mostly white) intensity (within the affected area only) a vertical strip 2 3/4" wide will begin to fuzz out (just to the right of samsung logo, 16 3/8" from screen edge), and soon turns black (from top to bottom). Changing to a darker scene immediatley ater will cause the black stripe to fade back in (it fuzzes and clears up again) and it starts working just fine....
                04-13-2021, 01:45 PM
              • Falki
                Colorful LCD Vertical Lines on Samsung ue55es8090
                by Falki
                Hello there, ive recently found an older 55inch Samsung SmartTV.
                Sadly it has vertical lines at the left and one line in the middle-right.
                I have already tested out the connections and have looked at the soldered ribbons of the LCD panel to see if some contacts got loose by pushing them a bit but with no success.
                I have factory resetted the TV as well but also with no luck.
                I am afraid that it is indeed a LCD Panel issue but there are NO scratches or any impact-marks..
                A similar issue has been posted as well but also with no actual response ...
                08-12-2025, 04:19 AM
