Vizio E421VO firmware file needed
  • crosstalk
    • Feb 2014
    • 68
    • Usa
    Hello. I picked up a Vizio E421VO with corrupt firmware. I found a bin file for a E320VL, which uses a similar main board. The TV is mostly working with this file, but the tuner doesn't find any channels. Could be a bad tuner--could also be wrong firmware for the tuner on the board.
    Does anyone out there have a E421VO firmware dump? Seems ridiculous that people sell programmed chips, but the files aren't available.
  • Kingdraykal
    • Jan 2017
    • Usa
    Re: Vizio E421VO firmware file needed
    Do u still have firmware for e320vl i need badly caint find anywhere. Or where did u find yours
    • Daniel Larsson
      Firmware file for LG SK10Y Soundbar stuck in Please wait loop needed
      by Daniel Larsson
      My LG Soundbar, SK10Y, has somehow ended up in an endless "PLEASE WAIT" loop and I am now starting to suspect that the firmware is causing this, and I can't manage to connect via the app to push a new firmware in as it never really starts.
      I can trick it to start via HDMI ARC and it actually starts up, flashes OPTICAL and then goes to ARC where the sound (including sub) is perfect, but the white led indicator keeps blinking and after 20 seconds it says "GOOD BYE" and shuts down.
      During these seconds the function button is not working...
      08-13-2025, 10:29 AM
    • Daniel Larsson
      Firmware file for Marantz NR1501 needed
      by Daniel Larsson
      I picked up a Marantz NR1501 that the seller said did not produce any audio, but was starting up just like normal. This was indeed the case and the hunt for damaged components started.
      After confirming all voltages and replacing all caps on this godforsaken HDMI-board I finally got sound from the AUX input, but all digital inputs are still dead.
      The service menu shows no DSP version so I desoldered IC1604 that should have the serial flash DSP firmware on it and made two dumps that turned out identical.
      The content of these seems to be useless as far...
      05-23-2025, 04:11 AM
    • GeckoGreen
      Samsung service bulletin: need firmware file for PN63C550 TV
      by GeckoGreen
      I'm hoping someone with access to the Samsung GSPN can help me. I need someone with access to download a firmware file for my PN63C550 TV, as it will fix a problem per the Samsung service bulletin.
      You can reference Samsung bulletin #:ASC20130528001 and I need the [2D63]LOGIC.bin file please.
      The full service bulletin is linked here: https://www.avsforum.com/attachments...3-pdf.1080602/
      Will you please help me get the [2D63]LOGIC.bin file for my TV?
      05-17-2025, 02:47 PM
    • m1ch43lzm
      Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
      by m1ch43lzm
      Hi everyone
      I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
      Programmer models: XGecu TL866II Plus / T48 / T56 / T76
      Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
      There's also an extra OTP Secu.R...
      09-06-2025, 05:47 PM
    • mohammed mohan
      BIOS file needed HP PROBOOK 445 G6 DA0X9KMB8E0 REV E
      by mohammed mohan
      BIOS file needed
      HP PROBOOK 445 G6
      DA0X9KMB8E0 REV E
      S/N 5CD92213CN
      No backup available
      10-29-2025, 05:25 AM
