Viewsonic n4785p tcon problem?
  • bleachedrock
    • 3
    Hi Guys, I have an old Viewsonic n4785P (aka VS12070-1M) LCD TV built January 2008. It's huge (thick) and doubles as a space heater but it has a nice bright picture and works well as a bedroom TV.
    I believe the Tcon board is toast (see https://youtu.be/_fgAEG3_R6k) and I wanted to know how specific of a replacement board do I need to get? For example:
    The existing tcon board is a popular V420H1-C07 board that has 3 inductors (some have only 2). The V420H1-C07 is printed on the board.
    There is also a sticker along the edge of the board with:
    M$35-D020223-L$TSR747400020
    I can find many V420H1-C07 boards with 3 inducers pulled from other manufacturers with matching IC numbers as my existing board.
    I can also find some V420H1-C07 boards with 3 inducers AND also have a matching M$35-D020223 part of the sticker AND matching IC numbers.
    I can not find full V420H1-C07 boards with a full matching sticker.
    Do I need to find a full match of board V420H1-C07, 3 inducer version, with matching IC's AND sticker or would any old V420H1-C07 with 3 inducers work?
    The only reason I'm waffleing on this is because some boards are ~ $17 and others ~$45 some are locally available in the USA and others are in China.
    Anyone familiar with older Tcon boards enough to give me a couple of tips?
    Thanks.
    BR-DC
  • kca
    by kca
    Hello all ~
    08-31-2025, 06:38 AM
  • x_orange90_x
    TCL 50S535 bad tcon or panel issue?
    by x_orange90_x
    Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
    03-29-2025, 11:02 PM
  • advant
    by advant
    02-03-2020, 12:25 AM
  • Hakuu
    by Hakuu
    Hi There,
    More Details
    TV Model - LG OLED77G1PUA
    07-12-2023, 02:37 PM
  • netgearnetgear
    TCL 43S423 TCON OR PANEL FAULTY???
    by netgearnetgear
    Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
    08-20-2025, 06:04 PM
