Dynex DX-22LD150A11 no pix no sound
  • jalinsta
    • Nov 2015
    • 6
    My grandaughter,s Dynex tv was dead. Replaced SG6742 in power supply.
    Now have 12v, 5v, red led comes on and changes to blue but nothing else works. There is no voltage on BL_ON, no voltage on Dim, 0.2 v on AC-OFF-detect. 5Volt regulator on main board is good. no sound, no pic, no backlight. No back light is out because one winding is open in the inverter xformer.
    The tv went out during a thunder storm. There is no visable evidence that it was hit by lightning. Fuse was not blown. How can i check the screen, if it is bad, it will not be worth repairing. Recommendations ?
  • CapLeaker
    Leaking Member
    • 8206
    Re: Dynex DX-22LD150A11 no pix no sound
    Check PSON signal from main board to PSU
    • jalinsta
      • Nov 2015
      • 6
      Thanks for your reply to my post. I have some knowledge on repairing CRT type tv,s but no experience repairing LCD tv,s. I don,t find any markings on the main board or power supply to indicate where i can find the PSON signal. In relationship to CRT TV,s, what is PSON and where can i find it. Is it AC or DC signal. I do not have a schematic.
      I have a scope if needed.
      • jalinsta
        • Nov 2015
        • 6
        PSON must be called BL-ON on Dynex tv,s. This signal is 3.2 v. I have 12v on the power supply going to a 5 volt regulator on the main board. Have 5 v out of the regulator to the main board.
          Dynex probably uses STBY for PS-ON (>2.5VDC = ON, <1V = OFF), the PS-ON is for turning on the rest of the power supply cicuits., the BL-ON is for turning the backlights circuit/backlcks, >2.5VDC = Backligts ON, <1V = Backlights OFF, DIM is the backlights dimming control, it can be analog 1V~5VDC typical, or PWM.
          How about uploading good clear pictures of the boards so we can see how they are connected together.
          • jalinsta
            • Nov 2015
            • 6
            7 Pictures uploaded, attached.
            • CapLeaker
              Leaking Member
              • 8206
              These pictures need to be a straight shot. For example, we are interested on that power supply picture top left there is a connector. Can't read the pinouts as the cable is hiding them.
              Anyhow provide the measurements we asked for so we can figure out what board has trouble.
              • jalinsta
                • Nov 2015
                • 6
                Power supply connectors attached. When turned on the pilot led goes from red to blue.
                Pin 1. DIM - -0.01 vdc
                BL_ON - 0 vdc
                Lamp-Err - 0 vdc
                12 terminals - 12.13 vdc
                5VBS - 5.0 vdc
                AC_off_Det - 0.19 vdc
                Power supply has 4, 2 pin sockets where plugs from the screen plug into.
                What value is the high voltage that goes to the screen for the backlight.
                Thanks for your help.
                Jack
                  Main board is not sending the command signal (BL-ON) to turn on the backlights circuit, no dimming control signal either.
                  'AC_off_Det - 0.19 vdc' This one I am not sure if it is normally HI, or normally LO.
                  Backlights lamp striking Voltage can be from 1500~2500V, and running Voltage can be from 1000~1500V all depend on the lamp size. Do not try to measure the Voltage with your DMM.
                  'No back light is out because one winding is open in the inverter xformer' If one of the two High Voltage winding is open, you still should see the backlights flash on for seconds before the protection circuit kicks in.
                  • ChaosLegionnaire
                    by ChaosLegionnaire
                    09-13-2022, 09:02 AM
                  • LEECH666
                    Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                    by LEECH666
                    Good day ladies and gentleman!
                    I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                    This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                    I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                    01-19-2024, 05:46 PM
                  • Christos Tsiligiannis
                    Marian Trace Alpha sound card repair help
                    by Christos Tsiligiannis
                    Hello to the forum.
                    My name is Christos, I am new to the forum here and i am posting from Greece.
                    So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                    To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                    So i tried asking for a schematic from the company and they would not give me one. Instead they...
                    11-18-2024, 05:26 AM
                    HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500T Specification for Upgrade or Repair
                    This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                    09-12-2024, 02:30 PM
                    HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i7-9700 Specification for Upgrade or Repair
