SAMSUNG ue40d6510 TURNING OFF AFTER 15secs
  • andrews7523
    • Apr 2015
    • 117
    • lancashire
    Hi i have a samsung ue40d6510 which comes on fine but after 10-15secs turns itself off. It does not come straight back on unless turned on by the remote/on button. Ive checked the caps but none are bulging.
  • Hamie
    • Apr 2014
    • 1383
    Re: SAMSUNG ue40d6510 TURNING OFF AFTER 15secs
    Unplug the mainboard.
    Plug in the tv, the backlights should come on and stay on.
    Do they go off after 15 seconds?
    • andrews7523
      • Apr 2015
      • 117
      • lancashire
      i just had a thought. How would i turn on the Tv without the main board being plugged in
      • CapLeaker
        Leaking Member
        • 8196
        Just plug the TV in. The PSU has a pull up resistor. So when you unplug the main board, and plug the TV in, the backlight comes on and stays on until you unplug the TV.
        • andrews7523
          • Apr 2015
          • 117
          • lancashire
          I've tried this but if the main board is unplugged the tv can't be turned on as the power button is connected to it. It does nothing without the main board being plugged in No backlights
          • andrews7523
            • Apr 2015
            • 117
            • lancashire
            Ive unplugged the Tv whilst turnt on and the Tv goes off
            • CapLeaker
              Leaking Member
              • 8196
              It won't stay on if you unplug it!
              Re read my other post again. A PSU with a pull up resistor doesn't need the main board with the power button to turn on the backlight.
                OK, the power supply/LED driver board has built-in pull-up resistors to allow you to do the self test of the power supply and the LED driver circuit without the need of the main board. So unplug the TV from the outlet, then unhook the cable between the power supply and the main board, plug the TV AC plug into the outlet, then you should see the backlights come on and stay on as long as the TV is plugged into the AC outlet (the main board is not active at this point).
                If the backlights stay on then you know the power supply, LED driver, and the Backlights LEDs are OK, if not then you need to do more troubleshooting of the power supply circuits, LED driver circuits, and testing of the LEDs.
                • andrews7523
                  • Apr 2015
                  • 117
                  • lancashire
                  Right I've plugged the Tv in with the cable to the main board loose so theres a connection to get the Tv turned on. Tv comes on but if i remove the cable to the main board tv goes off straight away. Does this mean the main boards at fault?
                  • flocko
                    • Nov 2012
                    • 1121
                    Read budm post 8 again? remove the plug to main board from power supply ,plug back into wall socket and turn on wall socket. the back light should come on together with all the supply voltages as well.
                    • CapLeaker
                      Leaking Member
                      • 8196
                      I give up
                      • comptek
                        • Aug 2013
                        • 606
                        un-plug main board ............ plug tv in and it does a self test and the backlights will come on like magic see if they stay on
                        its a self test ciruit built into the power supply just un-plug main board nothing else then plug into mains supply simple
                        • Hamie
                          • Apr 2014
                          • 1383
                          Right gonna give this one last try.
                          Main Board = the one with the HDMI inputs etc.
                          Power supply = the one with that connects to the plug.
                          The power supply and mainboard have a wire connecting both together.
                          Remove the wire (or just take out one end so they are no longer connected.)
                          • Hamie
                            • Apr 2014
                            • 1383
                            Unplug this wire here:
                            • andrews7523
                              • Apr 2015
                              • 117
                              • lancashire
                              Right guys sorry for the blonde moment. Tried this and no Backlights come on. What should i try check next, caps, diodes, resistors. Also maybe worth a mention that the Tv clicks when coming on and turning off but I've never come across this before.
                              • andrews7523
                                • Apr 2015
                                • 117
                                • lancashire
                                I dont understand what voltages should be going where, sorry I'm only a Beginner
                                • Hamie
                                  • Apr 2014
                                  • 1383
                                  what you are saying doest make sense,
                                  if the tv turns on for 15 seconds, then with the mainboard unplgged the backlight should at least appear for 15 seconds...
                                  once the mainboard is disconnected from the power supply you need to plug back in the tv to the AC socket.
                                  • thoma
                                    • Sep 2012
                                    • 268
                                    • andrews7523
                                      • Apr 2015
                                      • 117
                                      • lancashire
                                      Nothing happens, no backlights, no clicking, nothing...
                                      • comptek
                                        • Aug 2013
                                        • 606
                                        do you have a multimeter (DMM) we will need to know some voltages
                                          09-07-2024, 05:50 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-X01DE boardview and NP950XCJ-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 06:20 PM
