No picture 42PC3
  • paulstef
    • Dec 2013
    • 724
    Re: No picture 42PC3
    -VY ramps up from 0 to 27V in about 5ms, then stops and tries again afterabout 12ms. Does this a few times then stops and tries again after some more time.
    What do I supposed to have on -VY?
    • paulstef
      • Dec 2013
      • 724
      Ok, from the label on the panel it seems I should have -180 on -VY.
      • paulstef
        • Dec 2013
        • 724
        IPM is ok, no other bigger semiconductor is damaged. I separated the buffer from the sustain board, still the same weird -VY voltage ramps. Why they don't just give us the schematic!!!!
        • paulstef
          • Dec 2013
          • 724
          Just to conclude, it turns out that the little pnp- transistor Q2 in a SOT-89 package on the Y-sustain board, driver for the bigger transistors on the heatsink was also damaged. Tv works.
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
          • howardc64
            by howardc64
            07-24-2025, 05:17 PM
          • H34TO
            ITE IT8390 (IT8390E-256) programmer "ITE Download Board 4" user manual + firmware, flashing ITE ECs on the cheap
            by H34TO
            Recently I've gotten into EC flashing due to my broken laptop(s) and started frantically searching methods for flashing the IT5571E-128 chip on the cheap(due to me beaing a student and not having a job) and noticed that ITE newer chips can be flashed via ISP (In-System Programming) either via SMBus or the KBC (EPP - Enhanced Parallel Port) interface. While these can be achieved with programmers like SVOD4/3 or the RT809H/F those options are WAYYY out of my budget so I was horrified. But recently I stumbled uppon some programmers on aliexpress that claim they can program a variety of ITE chips...
            06-17-2025, 07:17 AM
          • ermals
            Samsung UN55H8000AF - No Picture, Working Backlight, Replaced T-Con Board
            by ermals
            Hi all!
            I've recently run into an issue with my Samsung UN55H8000AF LED TV displaying no image. I've done quite a bit of research in terms of what could be wrong with it. Below are the steps I've taken prior to reaching out here for some assistance:
            1. I've tried replacing the T-Con board (BN95-01594A), twice and have still experienced the same issue with all the boards I've tested with.
            2. I've tried to remove one side of the ribbon cable that goes from the T-Con board to the panel and still not getting any image on left or right side.
            3. I've checked voltages...
            08-01-2022, 10:35 AM
