Sony KV-36FV310
  • dprit
    • Jul 2015
    • 49
    Sony KV-36FV310
    Does anyone have a service manual for this Sony KV-36FV310? It will click a couple of times and there's a thump from the speakers and then the LED blinks 14 times. If I wait a few seconds and try again, same results. Thanks!
  • nuala
    • Aug 2013
    • 37
    Re: Sony KV-36FV310
    If you need the service manual e-mail me at curt.wolfe@gmail.com
    • sordids999
      • May 2013
      • 2152
      • uk
      Re: Sony KV-36FV310
      Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
      • Carlos#2003%
        Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
        by Carlos#2003%
        Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
        02-15-2024, 07:52 PM
      • kramer826
        Sony KD-55X8500F service manual BL-on signal
        by kramer826
        Hello , I am looking for a service manual or schematic information to find out where to measure BL-on signal backlight on signal from the mainboard.
        I have a tv which works fine and a spare main board that Ii am trying to fault find that is not turning the backlight on,6 flashes.
        The backlights work ok with other main board.
        Thankyou for any information
        07-14-2023, 03:50 AM
      • dkneyle
        Sony KDL-46HX850 Can't upgrade/update firmware
        by dkneyle
        Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
        Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
        09-25-2024, 10:44 PM
        Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
        This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
        09-06-2024, 05:27 AM
      • Xenon-Codex
        Need service manual for Sony STR-110
        by Xenon-Codex
        I can't find from anywhere. All channels are not tuning perfectly even with the roof antenna, and the sound is distorted.
        Sound from AUX is good....
        02-23-2023, 01:56 PM
