Panasonic TC-L50ET60 Possible Bad Panel
  • brewcity
    • Nov 2015
    Im having issues with a Panasonic TC-L50ET60, and I'm fearing that it's a bad panel, but it's presenting some unique symptoms with which I'm not familiar.
    Basically, the entire bottom half of the screen shifts up and down about a centimeter on a regular basis - it moves back and forth once about every two seconds. There are a few horizontal lines that are stationary, but there are also a few that shift with the picture and/or disappear.
    I know I've done a poor job of explaining. Hoping this video will help:
    https://youtu.be/pgykfKR9_Dg
    Thanks in advance for any and all assistance!
  • freakaftr8
    • Oct 2012
    • 3743
    Re: Panasonic TC-L50ET60 Possible Bad Panel
    Double post sorry...
    • freakaftr8
      • Oct 2012
      • 3743
      Looks to be a lower buffer board fault. Also known as an SD board. I would remove both upper and lower buffer boards make sure the screw Contacts are nice and tight then reconnect everything and make sure the screws holding the SC board are nice and tight
        It's an LCD. No buffer boards. So bad panel, unfortunately.
        • brewcity
          • Nov 2015
          That's what I was afraid of, but wanted to be sure before I parted it out. Thanks for the diagnosis!
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            This is Lcd freak
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              I also say bad Lcd panel.
              • howardc64
                LG 49UJ6500 LCD panel lighter band that goes away
                by howardc64
                49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
                Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
                02-19-2023, 12:13 AM
              • triplefour
                SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
                by triplefour
                TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
                tcon is built into mainboard.
                Only one cable goes to panel boards.
                there is a cable from one panel board to the other that links them.
                cost cutting measure that results in us having harder time to diagnose.
                removing the link to the second panel board allows TV to stay on with stable backlight but no image.
                used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board....
                07-28-2022, 07:59 PM
              • Storyteller12
                QN55Q60R Service Menu Panel Help
                by Storyteller12
                I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
                I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
                I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
                the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....
                01-13-2024, 01:57 PM
              • Ancient1
                I'm stuck . Panasonic TH-L32U20M panel's boards issue
                by Ancient1
                Hi
                The TV seem to start ( blinking green) but goes into blinking red. No display and or backlight. Full view photo.
                Actions :
                1. Disconnected Panel's Right, 2nd, board : TV comes ON (steady green , no blinking red )
                1a. You can see in two photos the B/W screen , fading blue "HDMI12" , and the wierd sides of the image, like an old CRT.
                Obviously the fault is from or on the Right, secondary board
                2. I taped the Flex tracks, ~2 tracks at a time- see Photo. The issue seems to be on the V lines (Assuming Data...
                09-03-2023, 03:51 AM
              • maneatingmonkey
                Missing LCD Panel Voltages VGH, VGL, VCOM (TCL 55P6US Sound & Backlight but NO Picture)
                by maneatingmonkey
                I have a TCL 55P6US with sound and backlight but no picture. This model does not have a T-CON board, and the right (rear perspective) panel board is fed from the left panel board. I have not been able to induce any change by disconnecting the secondary panel board or the tape cut-off method on the primary board.
                There are a bunch of voltages missing on the panel boards. I can't find any shorted caps of the panel boards, and all of the missing voltage rails read in the kiloohms, which leads me to suspect the issue may lie on the circuit board, rather than a short in the panel.
                03-27-2024, 07:17 AM
