Samsung PN50b550T2FXZA Dead
  • R1racer
    • Nov 2015
    • 66
    Hello every one ....Samsung PN50B550T2fxza was working great and one morning it shut it self down and power back up .Suspected power surge .Then thru the day it went completely dead, though it is the caps but they all appeared good. The only way i was able to bring it back to power back up is to disconnect the Main board ( BN96-12139A). I bought the manual and followed trouble shooting process i had standby light up front and TV was very responsive with picture and sound except it power it self down after 15-20 Minute minute to exact with all Voltage reading correctly at VA, Vscan & Vg ..fast forward .
    I did not want to dump money on a main board without extra support as i though man it could be power supply so my local electronic store trouble shot it and said main board .. However now when i brought it back home the screen was totally dead and no standby light , NO SMPS relay clicking NOTHING , No Logic B’d LED on, all AC Input voltage present , connector going to power supply show 122 AC ,no blown fuses . Pin #3 STBY =5v Yes , Pin #2 PS-On =0 V So since it is yes repair manual show replace main
    i took it back to the shop as the symptoms got from bad to worse after i picked it up ( specially i had picture , sound , standby light up in the panel ) they said it's main board . Then off course they told me the TV will be dead without a good main . Well it wasn't when i took it in and it was operational except it power it self off and goes dead and now it's nothing but weight. Well that did not go any where with them , So i took it home and I retested by starting at the SMPS (Power supply ) same result as my 1st test , SO i picked up a refurbish main board from e-bay seller stuck it in but got the same result = dead set with the same test result on the voltmeter.
    Whats the odd of me buying a bad Main board . Also what else they could off done( the electronic Shop) that resulted from having a TV that with some what functioning to nothing but paper weight ..
    I am buying another main but
    Does the revision # have to be the same when buying a refurbished main
    If the main board is truly bad would the set behave in this manner .
    What happened to my Logic B’d LED on , It use to function but now all is gone together
    i am open to all suggestions.
    Thank you
  • R1racer
    • Nov 2015
    • 66
    Re: Samsung PN50b550T2FXZA Dead
    No One
    • R1racer
      • Nov 2015
      • 66
      I should have Main board ( BN96-12139A) version 1016.1 ordered and on it's way , Should i be looking for something else ...
      Any one
      • freakaftr8
        • Oct 2012
        • 3743
        The model is known for having bad connections on the primary MOSFET to the power supply you might want to check the solder connections on the backside of the power supply near the primary side MOSFETs to see if you have a breach in connection. Where you still getting 5 volts to the main board?
        • R1racer
          • Nov 2015
          • 66
          Please explain Is the MOSFETS you refering to is the one show in the PIC #2 up close that where the ribbon cable goes and connect the main Board to power supply ..? Also marked cn801 connector ..?
          I am not getting any Power on Pin #2 going to Main board according to the manual when i connect my AS power cord but i have 5v for the standby on pin #3 ,
          Manual show the SMPS is the main power and the main power consider the small power to complete the circuit
          here is what i am going by
          • awyatt2
            • Feb 2012
            • 407
            • america
            you also might want to test the 2 diodes that are heat sink mounted in a to220 case. they are prone to failure on these power supplies. I have replaced four of them and they were all sets with no surge protector.
            • R1racer
              • Nov 2015
              • 66
              Which one specifically ... You want me to post up close pic of the SMPS if that help to point them out
              • awyatt2
                • Feb 2012
                • 407
                • america
                look at the component markings they are t0220 case mounted to a heatsink I don't remember the exact number following but they are marked with a d prefix . they are in an area with a few electrolytic caps I had to remove one to get the two diodes out, one is common anode and one common cathode. if they are bad I have a number for replacement they hold up fine as long as you insulate the tabs from the heatsink pad, I used silicone pads under mine. also possible you may have a bad startup cap as well. what I am reading is you are getting no power at all.
                • awyatt2
                  • Feb 2012
                  • 407
                  • america
                  here is a schematic of the power supply from my set they should be the same. maybe it will help to find problem. I don't have the main print and could not find one.
                  • R1racer
                    • Nov 2015
                    • 66
                    Thank you for attachment ...
                    awyatt2 : After i got the set back from the shop it's totally dead i mean dead dead ..YES no power light led in the front panel
                    when i hock the ac power cord to the set i do not get power LED up front like it use 2 , I am reading 5v at the STB pin #3
                    If i recall it back when i was trouble shooting if you disconnect the main the set will behave the same manner . The SMPS need the Main board to complete the circuit..but i could be wrong
                    However after removing the spare yesterday and putting back my original main the set momentarily clicked ..Leads me to belive that i still might have main board issue along with what freakaftr8 mentioned
                    • R1racer
                      • Nov 2015
                      • 66
                      Removed SMPS and took a close look to all solider joint , non loose or cracked , now damaged caps or sign of burning component , placed back to it's place and connected main board then AC but nothing else to it . I header the SMPS relay momentary click but No stby light .
                      • freakaftr8
                        • Oct 2012
                        • 3743
                        Time to get out the voltmeter and start checking things. First of all what do you have in relation to 5 volts DC going to the standby pin on the main board. Do you still have 5 volts?
                        • R1racer
                          • Nov 2015
                          • 66
                          Ok i am seeing 5v Pin3 Stby at the Main board end where the Ribbon cable connect , So i have 5v Pin 3 at the SMPS >>> 5v Pin3 stby at main board . However Pin #2 (PS On ) is Zero
                          • R1racer
                            • Nov 2015
                            • 66
                            Bump ...No ideas
                            • freakaftr8
                              • Oct 2012
                              • 3743
                              PS on will be low until the mainboard tells power supply to turn on then that number will go hi I believe on your model.
                              • awyatt2
                                • Feb 2012
                                • 407
                                • america
                                look the main board over and see if the shop clipped any components to test maybe they missed resoldering some component in line. I have all parts for a pn50c450 except screen but I think they are different mains.
                                • R1racer
                                  • Nov 2015
                                  • 66
                                  The main board is part # BN96-12139A V1016.1 , I have one on it's way
                                  I think the Shop did something to make it go from bad to worse ..
                                  • R1racer
                                    • Nov 2015
                                    • 66
                                    I agree 100% , In matter fact my initial trouble shooting according to the book to proof this theory was ,i disconnect every thing ( X main, logic, Y main , speakers ..Ect ) and only leave the Main and SMPS connected and see what happen . The TV use to work but obviously with no pic as the main was talking to the SMPS ..However after exactly 15 minute or 20 minute some times up to 45 minute this communication get lost and the SMPS shut's down to protect it self .. They only way i was able to bring it back to life is by disconnecting the main and reconnect .
                                    Now it got to the point where it's total black out so hopefully the MAIN am getting will bring it back to life
                                    • awyatt2
                                      • Feb 2012
                                      • 407
                                      • america
                                      where in nc are you? I have esr, scope, multimeters and can help with ps if you need to go further after you get the main board been thru 4 of these sets and have one myself they have a good pic when working properly.ight now we are watching a ln55 set I repaired my wife likes it better I like the plasma on fast scenes it dosent have the draggy motion like lcd's do. been told its my eyes but I see what I see.
                                      • R1racer
                                        • Nov 2015
                                        • 66
                                        I am locate at the Eastern part of NC , Morehead City NC to be specific . I really like the Plasma Display and i agree with you . I do not like the draggy motion either , It's not you or me it's the way they are ..Not crisp and clear like Plasma .. main board should arrive tomorrow , crossing my fingers
                                        • Asraf Atb
                                          Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
                                          by Asraf Atb
                                          Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
                                          Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
                                          I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
                                          01-27-2025, 05:02 PM
                                        • mrautom8
                                          Samsung TV UN75H6350AFXZC main board schematics?
                                          by mrautom8
                                          Schematics for the main board needed please. Sticker on board states BN94-07517A but the silkscreen says BN41-02157B. Cant find here or anywhere on the web.
                                          Backlights work when main boards disconnected. When connected and power button switched, the relay on the PSU board turns on for one second then back off.
                                          While relay is on, all voltage rails are present and steady (scoped) on main board.
                                          I love a good logic puzzle but getting lost without any schematics.
                                          No shorts on ANY capacitor main board.
                                          Thermal camera shows 3.3V inductor getting warm instantly but...
                                          10-19-2025, 06:32 PM
                                        • Dani_2024
                                          by Dani_2024
                                          10-28-2024, 05:06 PM
                                        • ygorsan
                                          by ygorsan
                                          🧩 Problem Summary:
                                          • I
                                          07-28-2025, 08:34 AM
                                        • Lee M.
                                          Samsung UN75RU8000FXZA bad main board?
                                          by Lee M.
                                          When plugged in it will click and cycle the BL on and off, no pic and does not respond to remote. When I disconnect the cable from the PS board to the main board and then plug it in the BL will come on and stay on. There are only two boards in this set, the LVDS cables from the panel driver boards connect directly to the main board. Since the BL comes on and stays on I'm thinking the PS board is ok and the problem is on the main board. Should I order another main board or do I need to do more testing? thanks, Lee
                                          11-08-2023, 07:46 PM
