Samsung PS50C450B1w Horizontal black lines
  • H22A
    • Sep 2015
    • 10
    Just wondering what might be causing this problem?
    Could it be a completely knackered panel, or possible buffer board related?
    Any help to fix appreciated.
    Paul
  • freakaftr8
    • Oct 2012
    • 3743
    Re: Samsung PS50C450B1w Horizontal black lines
    That panels seen better days. Faulty panel. The horizontal electrode nodes inside the panel behind the glass break connection from the electrodes on the panel. Unfortunately it's done for
    • H22A
      • Sep 2015
      • 10
      Thanks Freak
      • arctor
        samsung 50tu8070u black display with horizontal green lines, sound and backlight ok
        by arctor
        hi guy my friend gives me this tv a 50tu8070u that has no picture at all, sound ok, backlights ok. i tought it was a bad panel, but the tv has many horizzontal lines green, i tried with the tape method but nothing change, only the green lines disappear but still no picture. You that have more good than me, do you think it s a panel or can be the main board, because my friend wants buy a new main board....but the tv respond to the remote control, have sound only no picture so i think it s a panel problem that is so broken that i cant fix with tape...or i wrong if someone can help me thanks, i give...
        04-26-2025, 05:22 AM
      • noipi
        samsung Oled 65 Horizontal Lines and Flicker
        by noipi
        I have samsung 65", i bought it last january 2025 2nd hand, and last month got this problem, flickering with horizontal lines. any inputs if this is Motherboard replacement or the LCD tcon, can someone help me what to do, i saw in YT, someone says that to cover the flex connector of the unit. Sorry for my english i am asian. i include the video so someone can help me out. thanks...
        10-14-2025, 02:11 AM
      • Ihandyrepair
        Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
        by Ihandyrepair
        Hi guys
        I just started fixing 4k TV few months ago. so I am still learning a lot
        I got this tv from friend complaint is ghosting or horizontal lines on image.
        never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
        then it started to show the ghosting white image.
        I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
        it has 3 thin small boards at the bottom of the...
        12-05-2022, 04:18 PM
      • x_orange90_x
        Samsung UN46C8000XFXZA vertical bars/horizontal lines
        by x_orange90_x
        I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
        The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
        09-04-2023, 12:09 PM
      • CyberNinja
        Samsung plasma 50" TV, model PN50C540G3F, has black horizontal lines
        by CyberNinja
        First, the black horizontal lines even overlay the TV's menu. Does this behavior indicate that it's the plasma panel that's defective? If not for the black lines, the TV works just fine. I've cleaned the 6 connectors between the panel and the Y-buffer board, causing no change in the black lines. Visually, the 12 ICs on the Y-buffer look brand new (no holes, etc.). I put my fluke meter in continuity mode and tried to perform the "short" test on the 6 panel ports and found many shorts. But I don't think I'm doing the "short" test correctly and I'm hoping someone can provide guidance....
        01-10-2021, 09:38 PM
