50ps3000 z sustain
  • cvel
    • May 2015
    • 64
    • United Kingdom
    50ps3000 z sustain
    Hi all I have this tv which was working fine last night got up this morning and it wouldn't switch on. After some research I found the problem to be the z sustain what was happening was the tv was turning on screen flashes then tv turns off unplugged the z sustain and tv stays on. So now I now what the fault is my question is can the z sus be repaired if so how can I find out what the problem is on it and what component on it needs replacing. Thank you in advance for all help received.
  • sordids999
    • May 2013
    • 2161
    Re: 50ps3000 z sustain
    Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
    • cvel
      • May 2015
      • 64
      • United Kingdom
      Not sure if these pictures are any good to you
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Repair kit:
        http://www.ohmsupplies.co.uk/LG-50PS...D-EBR548626601
        • cvel
          • May 2015
          • 64
          • United Kingdom
          Thanks all but it's sorted now after closer inspection I found some dry solder on the z sus board. Reflowed them and works perfect again thanks again for all advice.
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Cool beans never seen a double sided pcb like this get cold joints but nice one
            • sordids999
              • May 2013
              • 2161
              nice one
              care to show via picture where u reflowed ?
              • cvel
                • May 2015
                • 64
                • United Kingdom
                Where the lumpy bits of solder (if that's makes sense) are on this pic something just didn't look right compared to the other solder so with nothing to lose I just re heated the solder and it all flattened down plugged it all back in and came straight on no problems. Not sure if there is any underlying fault that could of caused this but it's working for now so I'm happy with that.
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  What parts are above that solder ?
                  • cvel
                    • May 2015
                    • 64
                    • United Kingdom
                    Can't recall of the top of my head now but I think it was the red components (unsure of real name) by the big black thing if that helps
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      Probably Polly caps. Strange but nice fix.
                      • freakaftr8
                        • Oct 2012
                        • 3743
                        Hot and cold cycles followed by ROHS solder and subpar soldering by the factory. Nice fix!
                        • bohaboha
                          Samsung UE70TU6905 BACKLIGHTS AND SOUND ON NO PICTURES BUT SCREEN NOT DARK
                          by bohaboha
                          Hi it looks like everything works don't know where to test except the 390v in the 2 capacitor in the hot side of the power supply and the weird 180v in the diodes in the cold side that should be discharged it is writin on the circuit no more you can read what is written on the circuit quite srrange color mixiing yellow and white
                          anyhow i couldn't t read anything else
                          the backlight is on strong and the screen does not get dark or very dark but no pictures
                          the mainborad feels a bit hott on the black part i test it to 52 degree's against 34 to 40 on the rest of it
                          01-02-2025, 08:04 PM
                        • valvashon
                          LG 55UH6150- trouble powering up, then half lit screen (pictures!)
                          by valvashon
                          The 55" LG has been in the basement for a few months without being used. Turned it on yesterday, set came on as it should and showed a complete screen for about 5 seconds (was on a broadcast channel but no antenna was connected), then the screen went mostly dark with about 1/3 of the screen on the right lighting up with brighter lines in that lit part (sorry, no pictures of that). Power LED was cycling too, preventing the TV from fully powering up.
                          Pulled the back off, all boards looked OK. Pulled the LED connector, turned the set on to see if it would power up but I don't belive it...
                          11-24-2024, 12:08 PM
                        • 2elw
                          SVOD4 PCB pictures + parts
                          by 2elw
                          Hey, I find it very absurd that the SVOD4 costs so much and has zero documentation. I had no other choice than to buy it to unlock ECs, if there was any documentation or firmware avalible I could've made it or something simmilar. Anyways here are some of the most important parts:
                          STM32H723VGT6 MCU - It's a microcontroller by STMicroelectronics and its the whole brain of the SVOD4. It has flash memory for the firmware which can be updated by the SVOD4 program. Its also powered by the AMS117 which converts 5v into 3.3V. 7€ on AliExpress.
                          GW1N-UV9UG169C6/I5 FPGA - Its a...
                          07-04-2025, 12:23 PM
                        • Keshenatech1
                          LG 50PJ350 plasma blowing Y-Sustain board
                          by Keshenatech1
                          Hi, I was wondering if there's anyone here with experience on the LG50PJ350 plasma or similar models? When it came in, it had 7 shorted mosfet outputs on the Y-sustain board, Q02, 04,11, 22, 24, 26, and 28 were all dead shorted. I replaced them with the exact same type, checked their surrounding area for other open and shorted components and didn't see any further problems. But as soon as I hit the power button on the remote, I had a loud Pop! and Q22, 24, 26, and 28 are shorted out again. The other 3 seem to have survived. Someone on another forum had suggested the possibility of a shorted panel....
                          05-13-2020, 10:08 AM
                        • VitalComputing
                          Taking Pictures Of Large Circuit Boards
                          by VitalComputing
                          Hi friends,
                          I am trying to take good quality pictures of rather large desktop motherboards for a project I'm working on. I had a brilliant idea of scanning them with a flatbed scanner I have but it only focuses on the bits of the board that are flush to the scanning glass. And the through hole components tend to lift the main board from the scanning glass. Everything else just looks out of focus. So it seems that that option wont run.
                          I have been capturing the images with my iPhone 11 and it's okay but wont capture the whole board. I have to grab it in sections and...
                          11-22-2022, 04:15 PM
