Samsung UE37ES5500 BN41-01812A main board compatibility sa
  • andrews7523
    • Apr 2015
    • 117
    • lancashire
    I need a replacement board for this set and have noticed that they have the same Bn41 number on the actual board but a different Bn41 number on the bit where you can slot some sort of card in. Will this still work i know I've used boards from different sets on samsungs but ones I've had in stock this time I'm taking a gamble at £30-50 on Ebay.
    Help is much appreciated guys
  • sordids999
    • May 2013
    • 2158
    • uk
    Re: Samsung UE37ES5500 BN41-01812A main board compatibility sa
    Always try and match up the BN41 and the BN94 number
    • andrews7523
      • Apr 2015
      • 117
      • lancashire
      sorry thats what i meant.
      Correction:- The BN41 is the same
      The BN94 is different, what is this for or what does it mean??
      • flocko
        • Nov 2012
        • 1121
        • uk
        BN94-xxxxx and will end with a letter found on the white bar code sticker is the part number , BN41-xxx is board layout number and can and will be loaded with model spec components .a lot but not all BN94-xxxx letter prefix can be changed an F for a E /H but you would need to do some home work on that hope this is of help
          Essentially:
          BN41 = Blank board with no components and can be loaded in any configuration
          BN94 = Assembled board with required configuration
          Some BN41 can fit where BN94 is different, but this is not always the case.
          Generally if the panel resolution and manufacturer are the same (1080p, Samsung AMLCD for example) then it will work. Dimensional constraints, for example location of the ports, also come into play.
          • TLFonderie
            • Feb 2017
            • 11
            • Europe
            My question may be silly, but would that mean that a BN41-01812A could work for 32, 40and 50" models? And then... that would basically mean that it is just a matter of configuring the card.
            I noticed that I have a mainboard BN41-01812A that died on a 50".... and have one that I extracted from a 40" broken screen, and it looks physically identical. So I am wondering if I could use the latter to replace the dead one? If yes then, how to reprogram the card to work on the 50"?...
            • Yanleb
              Compatibility of Samsung Y Main boards LJ92-01732A no rev vs rev AA2
              by Yanleb
              Hi, I did look everywhere to know if Samsung Y Main boards LJ92-01732A without rev marking is compatible with LJ92-01732A rev AA2.
              If they are not compatible why did Samsung give them the same part number to begin with?
              08-04-2025, 11:35 PM
            • Davi.p
              Help diagnosing Samsung BN41-02844E main board
              by Davi.p
              model: BN41-02844E
              I want to connect serial debug line, but the usual scheme of 4 contacts for pins is present 3 times, under the board top part, if connect them always in the same way GND, RX, TX, i obtain the same very short log in right snd left ports , the center port gives me no output, i whish to be able to enter some menu or even the service menu trough this.. could anybody address me how to? Later i will swap RX-TX in the center port but almost suremy is disabled..
              thanks
              09-07-2025, 08:46 AM
            • bohaboha
              SAMSUNG MAINBOARD COMPATIBILITY BN41-02751B
              by bohaboha
              Hello everyone, hope you have had a lot of sun and a nice summer.
              I wonder and hope that these two Mainboards are compatible because they look like twins. one Native is BN41-02751B.000 and the same thing on the other printed on the circuit but they differ what is on the stick Native BN94-16627N the other BN94-16103q. don't know if the region issue can cause problems
              or maybe it's a dump question or even a settings question for them to fit
              is there anyone here who can help me sort out this question very thanksm...
              08-04-2025, 05:42 PM
              09-07-2024, 05:50 AM
            • Asraf Atb
              Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
              by Asraf Atb
              Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
              Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
              I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
              01-27-2025, 05:02 PM
