Help diagnosing Samsung BN41-02844E main board
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4535
    • Italy - Milan
    model: BN41-02844E
    I want to connect serial debug line, but the usual scheme of 4 contacts for pins is present 3 times, under the board top part, if connect them always in the same way GND, RX, TX, i obtain the same very short log in right snd left ports , the center port gives me no output, i whish to be able to enter some menu or even the service menu trough this.. could anybody address me how to? Later i will swap RX-TX in the center port but almost suremy is disabled..
    thanks
  • lotas
    • Jan 2016
    • 4840
    • Russia
    It's not that simple, your UART is blocked by software, you need to find dump eeprom 24C512 with debug activated.
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4535
      • Italy - Milan
      Yes, thanks, i forgot that, in some early 2010 years models i was able to modify a certain eprom to enable the debug, now it's almost impossible, but i have another board same BN41 where i can get the unlocked uart programming, the wish to do it is absent, also when i remove heatsink remain.a small damage by pliers.. not precise pliers.. board is almost brand new and i want to sell it as is..
      apart this, which one is the debug port?
      q
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4535
        • Italy - Milan
        Ok later i will note the keys sequence to activate debug mode in SM..
        • lotas
          • Jan 2016
          • 4840
          • Russia
          All Samsung motherboards have a closed uart, it is activated via the service remote control in the service menu or look for eeprom from such a chassis with an activated uart.
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4535
            • Italy - Milan
            yes i know, now the other mb is stuck in a Mass production test and remote is disabled, i have to wait the test ends
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4535
              • Italy - Milan
              i successfully activated the service mode: POWER OFF (Stby) - Info, menu, mute, power - wait 45sec - arrow down, enter, arrow down, enter, enter, left, return, return, return - POWER OFF
              now i was on the central port, this is the TCon software debug..
              now i watch US Open tennis final then i change port...
              The board appear to be in protection mode about tcon job, but it is not visible clearly by log, when connected to LCD it boot loops with no image, the other board works correctly, the screen is slighy defective.. this boards produces all voltages on tcon section when LCD is diisconnected..
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4535
                • Italy - Milan
                Left port from the back is the main software log, it is long kilometers, it never stops, also when put in the stby,..
                • Asraf Atb
                  Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
                  by Asraf Atb
                  Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
                  Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
                  I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
                  01-27-2025, 05:02 PM
                • mrautom8
                  Samsung TV UN75H6350AFXZC main board schematics?
                  by mrautom8
                  Schematics for the main board needed please. Sticker on board states BN94-07517A but the silkscreen says BN41-02157B. Cant find here or anywhere on the web.
                  Backlights work when main boards disconnected. When connected and power button switched, the relay on the PSU board turns on for one second then back off.
                  While relay is on, all voltage rails are present and steady (scoped) on main board.
                  I love a good logic puzzle but getting lost without any schematics.
                  No shorts on ANY capacitor main board.
                  Thermal camera shows 3.3V inductor getting warm instantly but...
                  10-19-2025, 06:32 PM
                • Dani_2024
                  by Dani_2024
                  10-28-2024, 05:06 PM
                • ygorsan
                  by ygorsan
                  🧩 Problem Summary:
                  • I
                  07-28-2025, 08:34 AM
                • Lee M.
                  Samsung UN75RU8000FXZA bad main board?
                  by Lee M.
                  When plugged in it will click and cycle the BL on and off, no pic and does not respond to remote. When I disconnect the cable from the PS board to the main board and then plug it in the BL will come on and stay on. There are only two boards in this set, the LVDS cables from the panel driver boards connect directly to the main board. Since the BL comes on and stays on I'm thinking the PS board is ok and the problem is on the main board. Should I order another main board or do I need to do more testing? thanks, Lee
                  11-08-2023, 07:46 PM
