Philips 42pfp5532d snowy picture
  • TvMad1
    • Nov 2015
    • 5
    Hi guys i have a philips 42pfp5532d it turns on ok but the picture is snowy and flickers a bit. When i checked the inside of the tv i found 6 bad capacitors which i have now changed but the tv still got the snowy picture. It also gives off a slight buzzing noise from the power board aswell. Anyone know what the problem could be thanks.
  • sordids999
    • May 2013
    • 2155
    • uk
    Re: Philips 42pfp5532d snowy picture
    Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
    • Rauni
      Philips 58PUS7805/12 showed no picture; after T-Con replacement, shows halo
      by Rauni
      Hello, this is my first post on this forum, and my first attempted to repair a TV.
      My Philips 58PUS7805/12 stopped working recently. It is not that old, about 5 years. We were on a trip for a few days and when we came back, it had stopped working out of a blue (Perhaps our house was hit by a lightning strike? Don't know.)
      Read from a guide that I should test if the screen shows picture with one of the T-Con cables disconnected. Did that, it showed perfect picture (first on left, later on right side).
      Read also that we should test what happens if we...
      10-01-2023, 12:06 AM
    • Schwoin
      Philips 243v5lhsb00 Monitor Picture too bright
      by Schwoin
      Hey everyone,
      the picture on my philips monitor looks way too bright so that black appears grey and colors also seem too bright.
      While i tried to tilt the screen a little bit while it was displaying a picture, i´ve noticed, that there appeared some purple pixels. In the following picture
      you can see them on the top half of the photo.
      At a certain point during the tilting, the picture looked normal again but as soon as i laid it back down, the purple pixels were gone and the picture was bright again.
      03-21-2023, 12:40 PM
    • madyoyo
      Philips 37pfl560: Yellow picture
      by madyoyo
      HI.
      I have a weird problem with an old Philips 37pfl560 TV i put out of storage: the picture have a noticeable yellow hue, and its not caused by the settings (did a factory reset). I've never seen this before. I will try to get a photo with a real camera, with my phone its hard to see because of automatic white balance, but in real live the whites are really yellow.
      Anyone have an idea of what can cause this? Can CCFL tubes get "warmer" with time? This tv have several analog inputs,so its nice for retrogaming....
      05-30-2025, 10:16 AM
    • charlesdutcher
      No picture issue in Philips Chassis FTL2.1
      by charlesdutcher
      My Plasma Philips 37inch chassis FTL2.1 does not show picture. It automatically goes into protection mode after 30 seconds (red led blinks at 3Hz)
      Is there someone having any symptom like this? How to fix it?
      Thanks in advance!​
      08-06-2024, 09:55 PM
    • groomit
      Philips 50PUS7363/12 Backlight but no picture
      by groomit
      I'm having trouble with above mentioned TV. Bought it defect.
      Picture was heavily compressed around the horizontal axis. Fiddeled and tried different things (mask clock lines, swap T-Con). But no difference.
      Then I identified a heating capacitor on the left hand Signal-PCB (?) below the display. Replaced it by hand soldering. Checked for shorts afterwards. But now the screen stays black.
      I can see backlight, but screen stays black.
      What I've tried:
      - Disconnect right side cable from T-Con -> same (backlight but no pic)
      - Disconnect left side...
      11-22-2024, 02:43 PM
