Philips L9.2EAA (yes, a CRT:) abnormal RGB amp. supply voltage
  • Amdry
    • Dec 2014
    • 12
    • Croatia
    G'day mates,
    yes, some CRTs are still alive...well this one barely.
    It's a Philips 20' L9.2E AA chassis, works perfectly but turns off after couple of minutes. Service mode shows error 12, and service manual says "Black current loop instability protection. The black current could not be stabilised. The possible cause could be a defect in one or more of the RGB amplifiers, RGB guns or RGB driving signals."
    I found that supply voltage of RGB amplifier is considerably larger than it should be! 195-200V instead of 160V! I checked all resistors and capacitors around horizontal output section, but no avail. Vbatt from main supply is 95V as it should be. Some other voltages generated in HOT are elevated too.
    Please comment, hope some of you still remember how to deal with these dusty buzzing big ass beasts.
  • Amdry
    • Dec 2014
    • 12
    • Croatia
    Re: Philips L9.2EAA (yes, a CRT abnormal RGB amp. supply voltage
    Oh my, just had to adjust G2 voltage as per instructions in service manual! Buzzing big bum bugger works again!
    Cheers
      • 31196
      lol
      philips did make good manuals for crt's
      • freakaftr8
        • Oct 2012
        • 3743
        Is that G2 drive a potentiometer on the flyback? If so I have seen hot and cold cycles start to change the resistance on the potentiometer overtime increasing. Yes sometimes just a tweak of the G2 drive will bring things back. I remember Sony when the G2 went to high it would blank out shutting down where others would just overdrive the CRT until it started flickering and dropping out because of the cathode couldn't handle the load
        Also given how much voltage a flyback has going through it and high current a lot of dust accumulates in that section and sometimes gets behind the potentiometer and starts causing it to do all sorts of crazy things
          • 31196
          pot problems on philips stuff is so rare i'v not heard of it.
          common on some cheap crap though, i remember a monitor from Amstrad/schneider that used to lose it's focus because of the pot.
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
            Adjustable Boost Power Supply DC-DC Constant Voltage Current Charging Module
            I want to know if I could hook up a solar panels to this boost converter would I have any issues doing and I would have issues what would they be
            https://www.ebay.com/itm/116497313155?var=416785404161
            Here are some of the description from the eBay seller
            The main parameters:
            1. Product name: High-power non-isolated DC boost module power supply.
            2. Product model: 100A2000W.
            3. Input voltage: DC12V-60V.
            4. Input current: 100A (maximum)....
            05-18-2025, 09:45 AM
          • Jembang
            coocaa 50S5G smart tv dropped voltage when connecting power supply to mainboard
            by Jembang
            good day hoping someone can lend a hand, im repairing smart tv 50 inch, status when turning on back light is dim but you can see the tv logo then slowly fading out to black, i check the supply to tcon, i only read 5+v, must be 12v, i removed lvds cable and check voltage to mainboard turned on its also 5v, then i remove the cable mainboard to power supply, i read 12v in power supply, thinking that the problem is in the mainboard, coz theres 12v in power supply, i also check while turning on checking volts in main board 12v dropping to 5v, im just new repairing in TV, hope someone see my post t...
            11-01-2024, 09:55 AM
            LM358 LM358S-13 Datasheet
            The LM358 LM358S-13 consists of two independent, high gain, internally frequency compensated operational amplifiers which were designed specifically to operate from a single power supply over a wide range of voltages. Operation from split power supplies is also possible and the low power supply current drain is independent of the magnitude of the power supply voltage.
            Application areas include transducer amplifiers, dc gain blocks and all the conventional op amp circuits which now can be more easily implemented in single power supply systems. For example, the LM358 series can be directly...
            10-07-2024, 04:12 AM
            How to modify a switching power supply that has voltage/current adjustable but powering it from a battery pack
            I have been pondering this question for a while but now I have see if this doable but I need to answer this question once and for all
            I would like to know how to safely do this undertaking my first thought is to solder wires to the main filtering capacitors and see
            what voltage I am getting and seeing if I can build a battery pack with voltage or not and if
            I can find a BMS balancing protection board at this voltage level and weather or not do I have use more than one BMS balancing protection board...
            05-11-2025, 05:22 PM
