Bad picture Insignia NS-39L700A12
  • jesselyons2002
    • Jul 2013
    • 82
    • usa
    Looks like its getting power. But the picture looks bad. Tried jiggling the cable to the top of the tv and on the board to the right. Just a little to see if it would do anything. Nothing. Thanks for your help
  • CapLeaker
    Leaking Member
    • 8352
    Re: Bad picture Insignia NS-39L700A12
    reseat the lvds cable on both sides a few times and pray for it to clear up.
    • jesselyons2002
      • Jul 2013
      • 82
      • usa
      Did that. Still the same thing
      • jesselyons2002
        • Jul 2013
        • 82
        • usa
        If I buy another main board. Do you think this would fix the problem ???
        • CapLeaker
          Leaking Member
          • 8352
          I wouldn't risk it. There is a vertical line going down the screen too. Try flexing and squeezing around the frame a little (tab bonds). If that doesn't yield nothing, I'd part it out or bin it. Those Insignias are cheap made.
          • jesselyons2002
            • Jul 2013
            • 82
            • usa
            I took apart the sheild around it. Press each ribbon slightly. You sure its a tab bond insure. How can I tell if its a bad main board ???
            • jesselyons2002
              • Jul 2013
              • 82
              • usa
              I just want to make sure before I scrap this tv
              • mattstolte
                • Dec 2013
                • 612
                • usa
                press on some of them tabs while tv is on and see if anything goes away i have seen a few people find bad caps on that arrest board. i think thats what its called. the board that has the tabs connected to it, i seen a few people find bad smd caps and replaced them and it worked, it was really amazing because i didnt anything on that board went to fault
                • jesselyons2002
                  • Jul 2013
                  • 82
                  • usa
                  Yeah pressed on the boards too. Nothing.
                  • srs
                    Insignia NS-50DR620NA18 w/ large vertical lines & no picture
                    by srs
                    I'm not sure what to do next and came here since y'all helped me fix a 50" plasma TV back in 2014, which is still working!
                    A friend gave me an Insignia NS-50DR620NA18 50" TV that suddenly developed large vertical lines on it. He said he had no idea what might have caused it and has replaced it with a larger TV. He was going to throw it away.
                    I did not notice any bulged or leaking caps on any board, the voltages produced by the power supply match the voltage that the pins are marked. The backlight leds are working. I have tried cleaning the ribbon cables...
                    04-22-2023, 02:40 PM
                  • Tr0ll
                    by Tr0ll
                    Original T-con:
                    First replacement T-con:
                    10-07-2023, 07:48 PM
                  • JJAAMM
                    by JJAAMM
                    Problem
                    07-06-2023, 06:01 AM
                  • jose6326
                    Insignia Ns-l22x-10a no picture only sound
                    by jose6326
                    When i power on the tv a "please wait" image appears then goes away then nothing after that only sound
                    When i was removing the back cover i heard a rattle.
                    Removed the metal plate and the heat sink was off (see pic)
                    would this cause a no picture/image issue?
                    What is used to put back the heat sink
                    07-30-2024, 11:03 PM
                  • TR103
                    by TR103
                    - it keeps rebooting
                    01-22-2025, 04:12 PM
