Panasonic tx-p50g10b
  • Emu9x
    • Sep 2015
    • 12
    Hi. Does anyone know what the latest firmware for this tv is? and where i can get it.
    tia
  • ned1
    • Feb 2014
    • 139
    • usa
    Re: Panasonic tx-p50g10b
    http://shop.panasonic.com/support-only/TC-P50G10.html
    • Emu9x
      • Sep 2015
      • 12
      Thanks for the link. Is that firmware compatible with the tx-p50g10b?
      As i know TC version is the american version of the TX.
      • freakaftr8
        • Oct 2012
        • 3743
        Probably will not work. European versions have that big connector. Not too sure what its called but we don't have it here in the states.
          SCART, you mean.
          I call it the revenge of France. Possibly the worst design for any multi-conductor cable ever conceived. Heavy cable, weak connector, small surface area.
          HDMI looks like a dream in comparison (it's pretty well engineered)
          • freakaftr8
            • Oct 2012
            • 3743
            Haha yep that's the one. I worked on at TV here in the states that had that start connector. Is a few years back and I really wish I remember the brand it was some cheap off brand but oddly it operated on 120 volts ac. But I'm pretty sure the power supply was a dual switching 120 - 220 auto
            • tw2005
              • Oct 2011
              • 6458
              Originally posted by tom66
              SCART, you mean.
              Amen
              • l3emarsh
                Firmware needed for A Panasonic TX-55FX555B 4K HDR TV
                by l3emarsh
                I have a Panasonc/vestel 55" 4K HDR TV and I need A copy of the Firmware.
                I replaced the main board and someone gave me a 43" FINLUX firmware as it is a Panasonic Vestel version, it got the TV working again but the PIP will not work, I can only assume that it's because the Firmware thinks it is 43" tv?
                I was greatfull for the TV to be workng again and it's been okay, but now I want to get it set up correctly.
                If anyone has a copy of the firmware I need PLEASE help me out and send me A copy.
                Greatfull for any help.
                01-11-2022, 07:44 PM
              • AlexWhat
                SONY KDL-65w850c need latest firmware 6.827
                by AlexWhat
                In 2022 SONY did "Termination of TV Software Update" for this model.
                I did find older firmware but it can't be installed over newer one (rolled back)
                Yes, got boot loop during android load so if that will not work then EMMC has to be replaced, I think.
                12-15-2024, 11:32 PM
              • TheUser
                Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                by TheUser
                Hello to everyone ,
                This is my first post here, and i would like to share with you a small story in case you can help me.
                Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                02-10-2024, 02:07 PM
              • gurj1979
                Ubiquiti firmware help. US-8-150W POE
                by gurj1979
                Hi guys.
                I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
                Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
                So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
                Got New chip and writes good.
                THE PROBLEM...
                It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
                Does anyone have a Good Firmware I can have?...
                07-22-2024, 05:13 PM
              • Fireballcz
                Synology DS109 latest firmware (PAT file)
                by Fireballcz
                Hello friends,
                I need the latest firmware for Synology DS109.
                The filename is DSM_DS109_3259.pat (about 170MB).
                Umpossible to download from Synology, because their support for old devices is discontinued as of 2023-05-31.
                Please does anybody have a backup?
                Many thanks in advance.
                07-03-2023, 02:39 PM
