Picked up a Samsung un55c6400 with clicking power supply issue. Found main to be faulty. Purchased used board for tv, was supposidly specifically for this tv. Tv works just inverted menu, and washed out tye dye colors. Main board numbers match exact, except the last letter is different. Can I change something in the service menu or find the exact board.
Samsung un55c6400 inverted, the dye picture .
Tags: None
Re: Samsung un55c6400 inverted, the dye picture .
Go into service menu and check LVDS settings. Something sounds off. Possibly bitrate. The most likely had a different manufactured panel or a different model panelLast edited by freakaftr8; 11-03-2015, 12:38 PM.Did I leave the soldering iron on? -
Factory reset from the service menu, tv works perfect!
May I ask what the ' inverted menu' means, upside down or mirror image?Never stop learning
Every image on the screen was "upside down" could not legably read any words. Colors were washed out.Comment
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
by TR103Hi, I have a Samsung UE50TU with:
- it keeps rebooting
- without cable between mainboard and lcd panel and with a jumpered... -
by JJAAMMThis was my main TV for the last 6 years. I'm not inclined to throw out a $2600 TV so quickly so I'm trying to investigate the issue.
Problem
TV was disconnected from power for 6 months during construction. When I plugged it yesterday picture was fine, after 30 seconds it dimmed then started developing horizontal lines, picture then starts to ghost vertically until it degrades into vertical streaks. TV always displays a perfect picture when cold. I can unplug TV for 5 minutes and plug it back in and picture is restored for 20 seconds. I can also keep it in standby mode... -
by Robby-GrHi all,
I’m trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality — very close to the original.
However, since the swap, the TV enters a boot loop (Samsung logo → restart) unless I enter the service menu and perform a reset.
The service mode had been previously modified — possibly by a technician or during the panel swap — and I suspect some key settings are mismatched for the European (Greece) market.
Additional issues:...11 Photos -
by YellowJacketHi friends,
a friend of mine gave me this TV to fix, with common SAMSUNG TV issue - damaged panel. Turning on, sound is present, but no picture. So I went directly to standard process, connecting two pads together with a wire ( see in the picture ), and then removing flex cables. With right flex connected, there was half screen working, but still no picture ( disappearing colors and similar weird stuff ) + working sound. With left flex connected, TV is restarting + working sound. I supposed, left side is damaged, so I then blocked all 8 CLK pins ( going from 0R resistors on the second... - Loading...
