lcd tv issues with sony KDL-46EX645, oCosmo Model CE4001-HM06P7A, jvc LT-50A330
  • shelby5041
    • Feb 2009
    • 1505
    • united states of america usa
    hi
    i bought 3 non working lcd tvs .... i will give the model # and brief description of what tv is doing ....any input would be appreciated...would like to repair all of them if makes economical sense
    sony KDL-46EX645, ...standby light is on....will not power on..no clicks..nothing when power button is hit.....caps on ps look ok...
    oCosmo Model CE4001-HM06P7A,....completely dead..no standby light....originally the hdmi port fried..u can see burn marks on frame of tv and old main board is fried in that area...seller replaced with another main board and now tv is 100% dead.....
    jvc LT-50A330 ....tv powers on with green light and has sound..there is a picture but no backlight....i tested and got 24v from ps to led driver board.....im thinking its a bad driver board but could be bad led lamps?
    anyone want to give me their input on any or all issues to direct me that would be great....i have the oCosmo Model CE4001-HM06P7A main board and jvc LT-50A330 driver board with me at work out of tv ....
    thank you
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: lcd tv issues with sony KDL-46EX645, oCosmo Model CE4001-HM06P7A, jvc LT-50A330
    Sony probably failed Psu, start separate thread will bring more attention and easier to help you.
    Cosoms probably blown fuse on Psu, start separate thread will bring more attention and easier to help you.
    Jvc probably failed Led inside panel however start a new thread will bring more luck.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Also upload pictures of the boards inside the tv will help us help you. Will look out for your threads
      • shelby5041
        • Feb 2009
        • 1505
        ok ill do a thread for each
        the driver board for the jvc has all good fuses...when i get home i will test for 24v coming out of board to led lamps....i didnt do that i assumed the board was bad but u are saying leds could be bad....?
        i wasnt able to take back off of sony once of the screws head was stripped will deal with it later....it sounds like a ps issue but there is a standby light so it could be main board also?
        once i get back off i can do further
        the ocosmo main fuse is ok
        • shelby5041
          • Feb 2009
          • 1505
          here are pics of the jvc driver board and ocosmo ps
          • freakaftr8
            • Oct 2012
            • 3743
            On the oCosmo are you receiving 5v standby?
            On the sony have you tried holding power while plugging it in to do a reset?
            Jvc no idea, I've seen my fair share of failed led strips already.
            • shelby5041
              • Feb 2009
              • 1505
              i have the ps board at work for ocosmo i will try to plug it in an test out of tv
              the sony i have not done any testing....
              jvc has to be either led strip or bad driver board....100%
              • shelby5041
                • Feb 2009
                • 1505
                i had a led lcd tv that had one bad led that prevented all leds to light up....i thought it was bad ps or drive board but it wasnt
                not sure if same here but i will know once i test the output side of driver board for voltages
                • shelby5041
                  • Feb 2009
                  • 1505
                  fyi the cosmo tv only has one board for entire tv..........the main...input and ps and led driver all on one board
                  • shelby5041
                    • Feb 2009
                    • 1505
                    freak....update....ocosmo
                    when i test for 5v on the main board with fried hdmi i get 5v
                    when i test for 5v on the replacmenet board i get 0v on the 5v pin
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      Thats probably because its in standby and isnt running, do you get standby led or anything ?
                      • shelby5041
                        • Feb 2009
                        • 1505
                        with the replacement main board i get nothing 100% dead
                        no lights at all....nothing....
                        hence no standby voltage either
                        • shelby5041
                          • Feb 2009
                          • 1505
                          when i test for standby 5v on the main board with fried hdmi i get 5v
                          when i test for standby 5v on the replacmenet board i get 0v on the 5v pin
                          • shelby5041
                            • Feb 2009
                            • 1505
                            where does the standby voltage come from?....which component can i check for....since i have a defective board that i get a 5v standby and one that gets 0v standby i was thinking i could swap defective component..instead of spending 75.00 for aother board
                            tv isnt worth much fixed....its a ultra low end..cheap ass made tv...with little value
                            • freakaftr8
                              • Oct 2012
                              • 3743
                              There's your problem with the replacement board. Check those big caps on the primary side for dc voltage. Should have about 170vdc
                              • shelby5041
                                • Feb 2009
                                • 1505
                                ok ill check in a bit....
                                they dont look bulged though
                                • ReeceyBurger123
                                  Never Give Up !
                                  • May 2014
                                  • 7325
                                  • Britain
                                  He didn't mean if they were failed. He meant for you to check if they have a voltage across them in stby which would indicate if the primary side is working.
                                  • shelby5041
                                    • Feb 2009
                                    • 1505
                                    also im novice...how would i safely check the caps for voltage...red to what and black to what on multimeter
                                    • shelby5041
                                      • Feb 2009
                                      • 1505
                                      i would imagine you would just read voltage across - and + legs on capacitor?
                                      • shelby5041
                                        • Feb 2009
                                        • 1505
                                        on the 4 caps in the center of the board on the ocosmo
                                        on the fried hdmi board i get 36v on two and 12v on two
                                        on the replacement board that seems dead i get 8v on two and 2v on two
                                        • HarryZ
                                          Sony XBR-49X800G networking issues
                                          by HarryZ
                                          Aloha. First post here, hope I can find someone to assist me.
                                          I have a Sony XBR49X800G with streaming issues. The issue mostly occurs watching sporting events (basketball and football). The picture will sometimes get pixelated, sometimes freeze for a few seconds while the audio continues, sometimes it's jerky. In other words, you get a headache watching the TV.
                                          My ISP provides 500 Mb service and I have verified that I have at least 500 Mb on ethernet, and something over 300Mb on WiFi. I installed Analiti on the TV (it's an Android TV) and I get ~ 70 Mb on both WiFi...
                                          01-26-2024, 04:49 PM
                                        • Carlos#2003%
                                          Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                          by Carlos#2003%
                                          Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                          02-15-2024, 07:52 PM
                                        • PontyPCs
                                          Sony Android TVs eMMC Issues
                                          by PontyPCs
                                          Hi people.
                                          I have been trying to get my head round these issues with the eMMC putting the TV in to a boot loop condition, or completely dead, when a dump of the Boot 1, Boot 2 and USERDATA partitions have been made, the MLC lifetime counter has been reset, using the original eMMC with the RPMB partition intact and the eMMC is flashed with the original dump, Netflix and a few other Apps don't work. i assume all the DHCP keys and factory programmed RPMB access Key will be contained within the original dump, and as we are re-flashing the original eMMC i would expect every thing to work....
                                          12-10-2023, 10:43 AM
                                        • ptcriserx3
                                          Sony trinitron crt bowed and side color issues
                                          by ptcriserx3
                                          Hi
                                          Ive got a vintage 2001 sony trinitron flat tube tv
                                          The image is slightly bowed and the left and right sides about 1-2in has fluctuating discoloration that comes and goes if i move or hit tv on sides
                                          See many images attached...
                                          Just windering if this is not fixable or something i can correct without getting too invloved
                                          Im trying to sell the tv
                                          06-17-2023, 07:27 PM
                                        • jb_Bak
                                          by jb_Bak
                                          CN6401
                                          Pin 01 NC
                                          Pin 02 NC
                                          Pin 03 "BL_ON": 0V
                                          Pin 04 "N/C"
                                          Pin 05 "STBY 3.3V": 3.5V
                                          Pin 06 "GND": N/C
                                          Pin 07 "AC_OFF"...
                                          09-27-2021, 04:52 PM
