LG 42PA4500 plasma TV no picture no sound
  • dfowler340
    • Oct 2015
    • 10
    I have a 3 year old LG 42PA4500-UF plasma TV that suddenly lost picture and sound, and I was hoping somebody could help diagnose the problem.
    When it first happened everything went black and the standby light on the front panel was a solid red. Trying to cycle the power (via remote and/or the push button on the TV) only resulted in the standby light flashing once and then going solid again.
    I opened up the back panel and confirmed with multi-meter that the two fuses on the power supply board are ok. I see no other evidence of electrical burnout on any of the boards or components.
    Also, now when I plug the power cord back in, the standby light on the front panel does not light up. The only response I get whatsoever is a slowly flashing red LED on the main board.
    Any suggestions for troubleshooting? I don't want to start replacing boards without a solid idea as to what the culprit is.
    Thanks in advance!
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: LG 42PA4500 plasma TV no picture no sound
    Hello, can you upload some pictures of the boards and the tv please.
    • dfowler340
      • Oct 2015
      • 10
      Hi...pictures are attached, thanks for responding
      • Hamie
        • Apr 2014
        • 1383
        Connect the 2 holes marked ext_auto_gen on your control board with a bit of wire. Paper clip etc.
        Disconnect the lvds cable (the one with the black tape over it).
        Power on tv, if you get test patterns you have a faulty main board.
        • dfowler340
          • Oct 2015
          • 10
          Thanks, I will give that a shot tonight.
          • dfowler340
            • Oct 2015
            • 10
            Hamie,
            I tried what you suggested however I still have no picture or sound. As before, the standby light on the front panel stays a solid red and flashes once when you press the power button. No other sounds or lights of any kind. Any other thoughts?
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Ok, do you have a DMM ?
              • dfowler340
                • Oct 2015
                • 10
                Yes
                • Hamie
                  • Apr 2014
                  • 1383
                  Ok unplug this connector here.
                  Try and power on the tv..
                  You'll notice also in the above picture there is a wire jumper marked VA-TP
                  There should also be a similar one marked VS-TP.
                  What voltage do you get at these 2 test points. You may find the voltage drops after a few seconds, so plug in, turn on, and quickly measure each test point.
                  Dc volts - red probe to wire jumper - black probe to chassis ground.
                  Be careful don't short anything out.
                  • dfowler340
                    • Oct 2015
                    • 10
                    VA-TP: 1.0 - 1.5 mV
                    VS-TP: 5.0 - 8.0 mV
                    In both cases the readings fluctuate within the range I've listed but they never drop off completely.
                    • Hamie
                      • Apr 2014
                      • 1383
                      Can you measure the voltage on either of these 2 capacitors.
                      Black probe to the negative leg red to the other.
                      Post back the voltage.
                      Also please upload a clear picture of this table.
                      • dfowler340
                        • Oct 2015
                        • 10
                        Both capacitors read about 161 volts. Attached is a picture of the table.
                        • dfowler340
                          • Oct 2015
                          • 10
                          Hamie - any suggestions for what to check next?
                          • Hamie
                            • Apr 2014
                            • 1383
                            what is the voltage when on the either of the primary capacitors when you press the on button? Does it rise or just stay the same?
                            • dfowler340
                              • Oct 2015
                              • 10
                              The voltage on both capacitors remains the same when pushing the ON button.
                              For what it's worth, both capacitors are now fluctuating between 375-400 V compared to the 161 volts that they were reading the last time I checked.
                              • jrpitale
                                • Dec 2016
                                • India
                                Guyz
                                I am having same problem with same model of LG plasma TV
                                Please suggest me to work around in same issue.
                                Jatien
                                • Andrew F. Ali
                                  • Jan 2014
                                  • 2450
                                  • Trinidad & Tobago
                                  Originally posted by jrpitale
                                  Guyz
                                  Jatien
                                  Start your own new thread.....Don't worry if it is the same issue.
                                  • KYBOSH
                                    Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
                                    by KYBOSH
                                    Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
                                    No picture but you hear the TV static (white noise) playing loud and clear.
                                    The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
                                    But it seems they didn't get too far and just left it.
                                    When I first took a look I was amazed at how pristine the inside looked.
                                    Its as if the TV had been in a time capsule.
                                    Caps looked like they were just pulled off the self.
                                    Copper coils had no sign of corrosion on...
                                    02-01-2023, 11:10 PM
                                  • TR103
                                    by TR103
                                    - it keeps rebooting
                                    01-22-2025, 04:12 PM
                                  • Mgiffune
                                    by Mgiffune
                                    06-09-2024, 10:28 AM
                                  • Ierwin
                                    by Ierwin
                                    05-13-2025, 03:31 PM
                                  • jchang
                                    Samsung UN70NU6900F no picture and no sound
                                    by jchang
                                    Hi all
                                    I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                    Symptom:
                                    No picture no sound.
                                    When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                    No sound at all.
                                    What I tried:
                                    1. I tried unplugging the left or right ribbon...
                                    01-09-2023, 06:28 PM
