Hitachi Plasma TV P42T501 Factory Reset
  • cbrian
    • Oct 2015
    • 5
    So I've got a Plasma TV that won't accept any inputs... it turns on but won't show anything at all. If I leave it unplugged for a week it resets and works again once I turn it on - but the next time I turn it off/on I have the same issue. I've tried upgrading it to newer firmware with an MMC card but the upgrade fails every time.
    So finally, I'm trying to do a factory reset, which is what the service manual says to do if the upgrade doesn't work. I found that I can get to the "Adjustment Mode" by hitting Menu+Menu+8+Select. Selecting FACT RESET flashes a few colors, then finishes on green as its supposed to. When I unplug/replug in the AC cord as the service manual says, nothing has happened. Nothing was reset. Any idea what I'm doing wrong?
  • masterm
    JVC LT-43C888 (manufactured by Vestel) does not start after trying factory reset, details below
    by masterm
    TV: JVC LT-43C888 (purchased in 2018). This is a smart TV with Netflix, Youtube, Freeview and other applications via 'Viewd' app store
    Problem with TV:
    - Netflix stopped working so i tried to do factory reset from the TV menu.
    - I confirmed on-screen but the factory reset did not happen even. It did not take me to 'first-time installation' screen as mentioned in the manual.
    - After waiting for some time, the TV went into a boot loop.
    - JVC logo comes on the screen and LED light flashes for some seconds, then it reboots again and the same thing happens
    04-30-2024, 03:03 AM
  • sheffieldyorky
    ZAB/ZAB A,B/ZYJA BLOCK DIAGRAM Acer Aspire
    by sheffieldyorky
    Hey there people
    While working on my Acer Aspire with the OS failing to load, I encountered a motherboard number of DA0ZHQMB6E 0 REV: E. I was getting nowhere fast or slow, for that matter.
    This is what I tried, but not in any order.
    Google
    YouTube
    BIOS
    Command Prompt (administrator privileges)
    On Google AND YouTube, I was getting mixed messages, try this and try that, but when you cross reference the advice it is either the wrong model (even though you enter the correct search term) a YouTube case in point, with the search term "how to...
    10-25-2025, 02:22 AM
  • KYBOSH
    Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
    by KYBOSH
    Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
    No picture but you hear the TV static (white noise) playing loud and clear.
    The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
    But it seems they didn't get too far and just left it.
    When I first took a look I was amazed at how pristine the inside looked.
    Its as if the TV had been in a time capsule.
    Caps looked like they were just pulled off the self.
    Copper coils had no sign of corrosion on...
    02-01-2023, 11:10 PM
  • mon2
    Hisense 55Q9G Android reset / factory firmware reload
    by mon2
    Hello. Have a 55" Hisense TV that starts to load the Android OS (no backlight issues) -> reaches the app screen where you can view the assorted icons including Netflix and always crashes at the same point just after this launch. If I quickly press the cursor buttons, the cursor can navigate to the settings menu but will power off just after a few seconds of this activity. Do not believe it is power related since the crash is very accurate in the boot cycle.
    After the OS 'crashes', the power does go off and the from white LED goes dark for about 20 seconds and then ON again....
    01-03-2024, 10:25 AM
  • pfrcom
    Reset/erase Hynix SC210 to factory default
    by pfrcom
    Some Googling made this seem straightforward, but it ain't necessarily so:
    First try was Hynix Drive Manager, supposed to be able to do PSID reset
    In Win7 x86 context, what shoddy software – this greeted me first time I clicked it from Start menu:
    After wild goose chase triggered by the OpenGL bit, I tried swapping graphics cards until penny dropped when it still objected to a Radeon HD3450
    How I got it work:
    1. Command prompt
    2. Change to install directory \Program Files\SK Hynix Drive Manager
    3....
    04-23-2022, 07:30 AM
