lg60pz570 no picture - overheating??
  • marty12345
    • Oct 2015
    • 5
    I have a lg plasma 60pz570 and recently picture went off (no backlight) but sound is still on while I was watching tv. I turned it off and back on and tv worked normally again for few minutes then goes black again.
    First time tv works ok for 30minutes or so and then after it last only few minutes. I also noticed that when the temperature is cooler the tv lasts much longer sometimes 2 hours or so but when its warm then goes off much quicker.
    This leads me to believe that its kind of an overheating issue??
    I have tested some voltage points when the picture goes off and both Va and Vs are good to both y sus and z sus boards but Vy, Vsc, Vzb read low or no voltage. 5V rail is good but 18V rail on the input of the control board reads very low voltage.
    I checked all the caps and visually checked all the boards both sides but cant find anything unusual.
    Would like to atleast narrow it down to a board but not sure where to go next.
    Any help would be much appreciated.
    Model no. : PDP60R30110
  • Hamie
    • Apr 2014
    • 1383
    Re: lg60pz570 no picture - overheating??
    Pictures?
    • marty12345
      • Oct 2015
      • 5
      Here are some pics
      • Hamie
        • Apr 2014
        • 1383
        Ok connect the 2 holes here beside resistors r51 and r52 with a piece of wire or paper clip etc.
        Now disconnect the lvds cable (P31) here:
        Plug in the tv.
        You should now get test patterns, let them run for as long as the fault usually occurs.
        If the fault doesn't happen then the main board is the problem.
        If the fault does happen then it rules the main board out.
        • Hamie
          • Apr 2014
          • 1383
          Also the way the this tv is wired it should run with the z-sustain disconnected.
          The image will be of poor quality but you can rule the z-sustain out by running the tv with z unplugged. If the fault happens the z-sus can also be ruled out.
          • marty12345
            • Oct 2015
            • 5
            Ok will try both of them.
            Will report back
            Thanks for your reply
            • marty12345
              • Oct 2015
              • 5
              I tried the test pattern and after a while the fault occured so as you said it wont be the main board.
              I have disconnected the z sus and the fault didnt occur. So by that u think its the z sus. Although i m not quite sure. Since i think its related to overheating issue the reason why the fault didnt occur because the picture was almost black when z sus was disconneted and the tv runs cooler when darker pucture??
              Is there any other tests i could perform?
              • Hamie
                • Apr 2014
                • 1383
                Well if the fault isn't occuring with the z-sustain unplugged it gives us somewhere to start.
                Since it seems to be heat related you could try heating up the z-sus with a hair dryer and see if the fault happens quicker.
                Alternatively, pop it in a freezer bag and freeze it for while and see if it lasts longer.
                Check the z-sus for dry cracked solder joints.
                Pay particular attention to coils and anything mounted on a heatsink.
                • Tr0ll
                  by Tr0ll
                  Original T-con:
                  First replacement T-con:
                  10-07-2023, 07:48 PM
                • JJAAMM
                  by JJAAMM
                  Problem
                  07-06-2023, 06:01 AM
                • TR103
                  by TR103
                  - it keeps rebooting
                  01-22-2025, 04:12 PM
                • Mgiffune
                  by Mgiffune
                  06-09-2024, 10:28 AM
                • CyberPhoenix
                  Issue with picture quality of Sony bravia TV
                  by CyberPhoenix
                  Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
                  01-22-2024, 02:08 AM
